J’ai un problème avec mon serveur, je voulais installer Phpmotion, j’ai donc réussi puis à la désinstallation je me retrouve maintenant avec 40 mails par jours :
[quote]PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/ixed.5.3’ - /usr/lib/php5/20090626/ixed.5.3: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: phpSHIELD: Unable to initialize module
Module compiled with module API=20060613
PHP compiled with module API=20090626
These options need to match
in Unknown on line 0[/quote]
Et j’ai aussi :
[quote]Warning: The file properties have changed:
File: /usr/bin/curl
Current hash: 188e79da8f122f0880e6501b599bbca07b3f3b29
Stored hash : 0c6ad17c503f5123a29566ca9e3797935b83efcd
Current inode: 248873212 Stored inode: 248885454
Current file modification time: 1384880317 (19-Nov-2013 17:58:37)
Stored file modification time : 1371990305 (23-Jun-2013 14:25:05)
Warning: Found enabled xinetd service: /etc/xinetd.d/ftp_psa
Warning: Found enabled xinetd service: /etc/xinetd.d/poppassd_psa
Warning: No output found from the lsmod command or the /proc/modules file:
/proc/modules output:
lsmod output:
Warning: Network TCP port 1524 is being used by /usr/sbin/portsentry. Possible rootkit: Possible FreeBSD (FBRK) Rootkit backdoor
Use the ‘lsof -i’ or ‘netstat -an’ command to check this.
Warning: Network TCP port 6667 is being used by /usr/sbin/portsentry. Possible rootkit: Possible rogue IRC bot
Warning: Network TCP port 31337 is being used by /usr/sbin/portsentry. Possible rootkit: Historical backdoor port
Warning: User ‘solutioniz’ has been added to the passwd file.
One or more warnings have been found while checking the system.
Please check the log file (/var/log/rkhunter.log)[/quote]
