Oui effectivement j’ai des messages d’erreurs:
May 3 15:15:28 debian qmail: 1146662128.567887 alert: cannot start: unable to read controls
May 3 15:42:20 debian qmail: 1146663740.411713 alert: cannot start: unable to read controls
May 3 16:10:43 debian qmail: 1146665443.897617 alert: cannot start: unable to read controls
May 3 17:37:06 debian qmail: 1146670626.196120 alert: cannot start: unable to read controls
May 4 10:33:59 debian qmail: 1146731639.208431 alert: cannot start: unable to read controls
May 5 17:45:21 debian qmail: 1146843921.394667 alert: cannot start: unable to read controls
May 5 17:50:08 debian qmail: 1146844208.367465 alert: cannot start: unable to read controls
May 9 10:48:24 debian qmail: 1147164504.780430 alert: cannot start: unable to read controls
May 9 16:47:52 debian qmail: 1147186072.040988 alert: cannot start: unable to read controls
May 9 16:48:28 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 9 16:48:38 debian last message repeated 2 times
May 9 16:58:14 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 9 16:58:24 debian last message repeated 2 times
May 9 16:59:50 debian last message repeated 3 times
May 9 17:00:10 debian qmail: 1147186810.432737 alert: cannot start: unable to read controls
May 9 17:00:41 debian qmail: 1147186841.605815 alert: cannot start: unable to read controls
May 9 17:01:04 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 9 17:01:14 debian last message repeated 2 times
May 9 19:19:57 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 9 19:20:07 debian last message repeated 2 times
May 9 19:22:06 debian last message repeated 3 times
May 9 19:22:45 debian last message repeated 6 times
May 9 19:25:25 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 9 19:26:21 debian last message repeated 14 times
May 9 19:29:20 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 9 19:29:30 debian last message repeated 2 times
May 10 11:28:51 debian qmail: 1147253331.054297 alert: cannot start: unable to read controls
May 10 11:34:39 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 10 11:34:49 debian last message repeated 2 times
May 10 11:57:29 debian qmail: 1147255049.539255 alert: cannot start: unable to read controls
May 10 11:57:50 debian qmail: 1147255070.861637 alert: cannot start: unable to read controls
May 15 16:32:26 debian qmail: 1147703546.751857 alert: cannot start: unable to read controls
May 15 16:35:55 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 15 16:36:05 debian last message repeated 2 times
May 15 16:38:36 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 15 16:38:46 debian last message repeated 2 times
May 15 16:48:44 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 15 16:48:54 debian last message repeated 2 times
May 15 16:53:42 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 15 16:53:52 debian last message repeated 2 times
May 15 17:52:49 debian imaplogin: LOGIN FAILED, ip=[::ffff:192.168.0.210]
May 15 17:53:55 debian last message repeated 3 times
May 15 17:54:05 debian last message repeated 2 times
j’ai fait ce que tu m’a di stonfi:
debian:~# locate defaultdelivery
locate: warning: database `/var/cache/locate/locatedb' is more than 8 days old
debian:~# updatedb
debian:~#
il ne m’affiche plus rien quand je fait le locate…
merci beaucoup pour ton aide stonfi en tout cas
Pourquoi tu t’énerve tt seul? j’ai pas intallé qmail “salement” mais j’ai bien suivi la logique des choses! c’est pour sa ke j’arrive a le configurer de mon Webmin! le seul problème c’est qu’il ne se lance pas ni du shell ni de webmin…
