Quelques questions au sujet de NVIDIA
Hi,
Lorsque que j’ai installé la version etch-and-half 64 bits, l’interface graphique était installée.
J’ai voulu faire une modification, au niveau de la résolution, dans xorg.conf. Pour ça, j’ai fait un dpkg-recofigure xserver-xorg.
Ce qui a donc fait les changement suivant, par rapport à mon fichier de conf précédent :
sh-3.1# diff xorg.conf xorg.conf.20080829142638
36a37
  Load    "i2c"
75c76
< HorizSync 28-40
  HorizSync       28-84
86c87
< Modes “800x600” “640x480”
          Modes           "1680x1050" "1600x1200" "1024x768" "800x600" "640x480"
90c91
94c95
98c99
102c103
106c107,108
          Modes           "800x600"
          #Modes          "1680x1050" "1600x1200" "1024x768" "800x600" "640x480"
Toutefois, lorsque je fais un startx, j’ai des messages d’erreurs, que je retrouve dans
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux Monstre 2.6.24-etchnhalf.1-amd64 #1 SMP Mon Jul 21 10:36:02
UTC 2008 x86_64
Build Date: 01 June 2008
Before reporting problems, check wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Aug 29 16:01:01 2008
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
) |–>Screen “Default Screen” (0)
() | |–>Monitor “Ãcran générique”
) | |–>Device “nVidia Corporation NVIDIA Default Card”
() |–>Input Device “Generic Keyboard”
) |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/X11R6/lib/X11/fonts/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi/” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/100dpi” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/75dpi” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/cyrillic,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(–) using VT number 8
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,29c0 card 103c,2a6f rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,29c1 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1a:0: chip 8086,2937 card 103c,2a6f rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2938 card 103c,2a6f rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,293c card 103c,2a6f rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,293e card 103c,2a6f rev 02 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,2940 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1c:2: chip 8086,2944 card 0000,0000 rev 02 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2934 card 103c,2a6f rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2935 card 103c,2a6f rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2936 card 103c,2a6f rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,2939 card 103c,2a6f rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,293a card 103c,2a6f rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 92 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2916 card 103c,2a6f rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,2822 card 103c,2a6f rev 02 class 01,04,00 hdr 00
(II) PCI: 00:1f:3: chip 8086,2930 card 103c,2a6f rev 02 class 0c,05,00 hdr 00
(II) PCI: 01:05:0: chip 11c1,5811 card 103c,2a6f rev 70 class 0c,00,10 hdr 00
(II) PCI: 02:00:0: chip 10ec,8168 card 103c,2a6f rev 02 class 02,00,00 hdr 00
(II) PCI: 04:00:0: chip 10de,0402 card 1043,034e rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,4), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 4: bridge is at (0:1:0), (0,4,4), BCTRL: 0x001a (VGA_EN is set)
(II) Bus 4 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xfa000000 - 0xfeafffff (0x4b00000) MX[B]
(II) Bus 4 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 3: bridge is at (0:28:0), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2: bridge is at (0:28:2), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfeb00000 - 0xfebfffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xf8f00000 - 0xf8ffffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf9f00000 - 0xf9ffffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(4:0:0) nVidia Corporation unknown chipset (0x0402) rev 161, Mem @ 0xfd000000/24, 0xd0000000/28, 0xfa000000/25, I/O @ 0xdc00/7, BIOS @ 0xfeae0000/1
7
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xf8ff0000 - 0xf8ffffff (0x10000) MX[B]
[1] -1 0 0xfebff000 - 0xfebfffff (0x1000) MX[B]
[2] -1 0 0xf9fff000 - 0xf9ffffff (0x1000) MX[B]
[3] -1 0 0xf9effc00 - 0xf9effcff (0x100) MX[B]
[4] -1 0 0xf9eff000 - 0xf9eff7ff (0x800) MX[B]
[5] -1 0 0xf9eff800 - 0xf9effbff (0x400) MX[B]
[6] -1 0 0xf9ef4000 - 0xf9ef7fff (0x4000) MX[B]
[7] -1 0 0xf9efec00 - 0xf9efefff (0x400) MX[B]
[8] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MXB
[9] -1 0 0xfa000000 - 0xfbffffff (0x2000000) MXB
[10] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[11] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[12] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[13] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[14] -1 0 0x0000c080 - 0x0000c09f (0x20) IX[B]
[15] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
[16] -1 0 0x0000c480 - 0x0000c487 (0x8) IX[B]
[17] -1 0 0x0000c800 - 0x0000c803 (0x4) IX[B]
[18] -1 0 0x0000c880 - 0x0000c887 (0x8) IX[B]
[19] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[20] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[21] -1 0 0x0000b880 - 0x0000b89f (0x20) IX[B]
[22] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[23] -1 0 0x0000b480 - 0x0000b49f (0x20) IX[B]
[24] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[25] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xf8ff0000 - 0xf8ffffff (0x10000) MX[B]
[5] -1 0 0xfebff000 - 0xfebfffff (0x1000) MX[B]
[6] -1 0 0xf9fff000 - 0xf9ffffff (0x1000) MX[B]
[7] -1 0 0xf9effc00 - 0xf9effcff (0x100) MX[B]
[8] -1 0 0xf9eff000 - 0xf9eff7ff (0x800) MX[B]
[9] -1 0 0xf9eff800 - 0xf9effbff (0x400) MX[B]
[10] -1 0 0xf9ef4000 - 0xf9ef7fff (0x4000) MX[B]
[11] -1 0 0xf9efec00 - 0xf9efefff (0x400) MX[B]
[12] -1 0 0xfeae0000 - 0xfeafffff (0x20000) MXB
[13] -1 0 0xfa000000 - 0xfbffffff (0x2000000) MXB
[14] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MXB
[15] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[19] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[20] -1 0 0x0000c080 - 0x0000c09f (0x20) IX[B]
[21] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
[22] -1 0 0x0000c480 - 0x0000c487 (0x8) IX[B]
[23] -1 0 0x0000c800 - 0x0000c803 (0x4) IX[B]
[24] -1 0 0x0000c880 - 0x0000c887 (0x8) IX[B]
[25] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[26] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[28] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[29] -1 0 0x0000b480 - 0x0000b49f (0x20) IX[B]
[30] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[31] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IXB
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: “nv”
(II) Loading /usr/lib/xorg/modules/drivers/nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 2.0.3
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache™, GeForce 6200SE TurboCache™,
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8400 GS, GeForce 8600M GT, GeForce 8700M GT,
Quadro FX 370, Quadro NVS 320M, Quadro FX 570M, Quadro FX 1600M,
Quadro FX 570, Quadro FX 1700, GeForce 8500 GT, GeForce 8400 GS,
GeForce 8300 GS, GeForce 8600M GS, GeForce 8400M GT,
GeForce 8400M GS, GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M,
Quadro NVS 135M, Quadro FX 360M, Quadro NVS 290, GeForce 8800 GT,
Quadro FX 3700
(II) Primary Device is: PCI 04:00:0
(–) Chipset GeForce 8600 GT found
(II) resource ranges after xf86ClaimFixedResources() call:
[27] -1 0 0x0000b880 - 0x0000b89f (0x20) IX[B]
(II) resource ranges after probing:
[16] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[17] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[18] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[22] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[23] -1 0 0x0000c080 - 0x0000c09f (0x20) IX[B]
[24] -1 0 0x0000c400 - 0x0000c403 (0x4) IX[B]
[25] -1 0 0x0000c480 - 0x0000c487 (0x8) IX[B]
[26] -1 0 0x0000c800 - 0x0000c803 (0x4) IX[B]
[27] -1 0 0x0000c880 - 0x0000c887 (0x8) IX[B]
[28] -1 0 0x0000c000 - 0x0000c01f (0x20) IX[B]
[29] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[30] -1 0 0x0000b880 - 0x0000b89f (0x20) IX[B]
[31] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[32] -1 0 0x0000b480 - 0x0000b49f (0x20) IX[B]
[33] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[34] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IXB
[35] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[36] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module “int10”
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(–) NV(0): Console is VGA mode 0x3
(**) NV(0): Depth 24, (–) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(==) NV(0): Using hardware cursor
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(–) NV(0): MMIO registers at 0xfd000000
(–) NV(0): Linear framebuffer at 0xd0000000
(II) NV(0): MMIO registers mapped at 0x2b7c24af8000
(–) NV(0): Total video RAM: 512.0 MB
(–) NV(0): BAR1 size: 256.0 MB
(–) NV(0): Mapped memory: 256.0 MB
(II) NV(0): Linear framebuffer mapped at 0x2b7c25af8000
(II) Loading sub module “i2c”
(II) LoadModule: “i2c”
(II) Loading /usr/lib/xorg/modules/libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.2.0
(II) Loading sub module “ddc”
(II) Reloading /usr/lib/xorg/modules/libddc.so
(–) NV(0): I2C map:
(–) NV(0): Bus 0 -> DAC1
(–) NV(0): Bus 0 -> SOR0
(–) NV(0): Bus 1 -> SOR1
(–) NV(0): Load detection: 340
(II) NV(0): I2C bus “DDC” initialized.
(II) NV(0): Probing for EDID on I2C bus 0…
(II) NV(0): I2C device “DDC:ddc2” registered at address 0xA0.
(II) NV(0): I2C device “DDC:ddc2” removed.
(II) NV(0): … none found
(II) NV(0): I2C bus “DDC” removed.
(II) NV(0): Probing for EDID on I2C bus 1…
(–) NV(0): Trying load detection on DAC1 … nothing.
(–) NV(0): Trying load detection on DAC2 … nothing.
(EE) NV(0): No display devices found
(II) UnloadModule: “nv”
(II) UnloadModule: “ddc”
(II) UnloadModule: “i2c”
(II) Unloading /usr/lib/xorg/modules/libi2c.so
(II) UnloadModule: “int10”
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
je suis d’autant plus étonné que si je fais un :
sh-3.1# lsmod |grep nv
sh-3.1# lsmod |grep nvidia
J’ai rien (alors que je pense que j’aurais dû trouver quelque chose).
Et je ne peux pas les monter, bien sûr.
Alors je ne sais pas : il y a peut-être des problèmes de fonts. Il y a peut-être un pb de compilation de nvidia (j’ai installé gcc après mon isntallation, après tout, mais bon… Je sais que mon noyau actuel a été initialement compilé avec gcc-4.1.1, je crois, tandis que j’ai gcc-4.1, à présent… je ne sais pas si ça fait une grosse différence).
J’ai un noyau que je peux dépaqueter (construit hier), aussi, avec la version de gcc que j’ai installé.
si je fais un module-assistant,
Je peux installer - en cochant - i2C, nvidia-kernel-legacy et nvidia kernel… Je suppose que cela aurait dû être installé au départ, comme je le supposait (après tout, javais X11 et gnome sans pb), non?
Alors - je ne connais pas nvidia - je dois installer et compiler le module de nvidia, finalement ? (driver nvidia ou nv, au fait?) Et les fonts à part?
Cordialement,
Chris
Y a moyen de récupérer tous les fonts qui nous intéressent?
De base, Debian tourne avec le module nv pour faire fonctionner ta carte nVidia GeForce 8600 GT.
A mon avis, nv ne gère pas les résolutions demandées pour ta carte (“1680x1050” “1600x1200” “1024x768” “800x600” “640x480”).
Soit tu essaies une résolution inférieure, ou soit il te faut installer le driver proprio via module-assistant en t’aidant du tuto de Debianhadic.
En sachant qu’il te faudra compiler en prenant le nvidia-kernel-source de Sid, celui de Etch ne prenant pas en compte ta carte.
Non, de plus les nvidia legacy sont des drivers fait pour les cartes anciennes. La tienne est très récente.
Ah, merci pour la réponse. Mais… Avant de changer le fichier (et j’ai pas changé grand-chose… grrr), j’avais l’interface de démarré sans problème. Pire, encore : si je remets la copie du précédent fichier, ca ne change rien! Je ne comprends pas. Si la carte ne prends pas en compte les résolutions… pourquoi elle les a pris en compte avant la modification?
Et, lol, ce tuto, où je peux le trouver?
Je prends note pour kernel legacy (logique : on retrouve souvent ce type de dénomination lorsqu’on recompile un noyau, j’aurais dû m’y attendre). A quoi correspond i2c, pendant que j’y pense?
Thx,
Chris
essaye de mettre un fichier vide: puis utilise l’outil (paquet) nvidia-xconfig
Le tuto se trouve dans la section Trucs et Astuces.
ok,
Je vais voir tout ça ce soir. Panthère, un fichier vide? un xorg.conf vide, tu veux dire?
Dsl pour l’absence : je n’avais plus internet (Argghhh…), mais maintenant c’est ok.
Thx,
Chris
non: pas de xorg du tout pour que tout se fasse en autodetect.
A priori, avec un fichier vide, il y a des versions de X qui plantent.
Il faudrait que je dégage le fichier xorg.conf, carrément, dans ce cas? (je vais prévoir une copie quelque part, quand même…) et que je passe par un dpkg-reconfigure, si j’ai bien compris? (ou nvdia-xconfig? je ne connais pas encore ce paquet : je materai tout à l’heure sur la toile pour voir de quoi il s’agit).
Thx
Chris
non tu supprimes le xorg.conf et tu lances startx.
Niark! Ca ne marche pas : ça stoppe après ceci :
Current Operating System: Linux Monstre 2.6.24-etchnhalf.1-amd64 #1 SMP Mon Jul 21 10:36:02 UTC
2008 x86_64
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Aug 29 15:22:14 2008
Fatal server error:
no screens found
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
Pour info perso et y voir plus claire : je suppose que “(EE) NV(0): No display devices found” signifie que je n’ai pas de driver, n’est ce pas? Dans ce cas, je vais vraiment devoir recompiler. Par contre, pourquoi, à mon install, j’avais une interface dans ce cas? Le serveur utilisait donc autre chose que la carte graphique pour l’install? Sur les carte mère permettant l’utilisation d’une carte graphique fille, il y a tout de même un chipset intégré, peut-être, qui serait utilisé, par défaut, par le système pour l’interface graphique? N’étant pas très “matériel”, je n’en suis pas totalement certain, cependant, ça expliquerait déjà une partie du pourquoi du comment.
Thx,
Chris
Lol, personne sait, pour ma question ci-dessus??
Par contre, très utile, man nv :
SUPPORTED HARDWARE
The nv driver supports PCI, PCI-Express and AGP video cards based on the following NVIDIA chips:
   RIVA 128              NV3
   RIVA TNT              NV4
   RIVA TNT2             NV5
   GeForce 256, QUADRO   NV10
   GeForce2, QUADRO2     NV11 & NV15
   GeForce3, QUADRO DCC  NV20
   nForce, nForce2       NV1A, NV1F
   GeForce4, QUADRO4     NV17, NV18, NV25, NV28
   GeForce FX, QUADRO FX NV30, NV31, NV34, NV35, NV36, NV37, NV38
   GeForce 6XXX          NV40, NV41, NV43, NV44, NV45, C51
   GeForce 7XXX          G70, G71, G72, G73
   GeForce 8XXX          G80, G84, G86, G92
Cela confirme le lien que tu m’as envoyé, AnatomicJC. Pas de doute, man est ton pote.
Thx,
Chris
Cela correspond à quelle carte? nv/etch ne supporte pas toutes les cartes nvidia. Tu devrais peut être installer nvidia proprio
edit: un epu une redite ce message, je n’avais pas lu la suite…
LOL!
En effet, sur cet aspect là, anatomicJC m’a répondu, et m’a même renvoyé sur un lien qui montre quelles sont les cartes supportée. Cependant, le man nv nous montre aussi quelles cartes sont supportées ou non - du moins c’est comme ça que je l’interprète - et on ne voit pas la mienne, en l’occurence une 8600GT, qui apparemment est “trop récente” (muarf, quand je me suis pris le PC, il m’avait semblé que la carte avait bien un an ou deux, déjà… ce qui est pourtant une éternité en informatique, déjà).
Par contre, quand vous parler de driver “proprio”, cela sous-entends que les pilotes présentés chez Debian sont des pilotes totalement libres de droit et surtout écrit indépendamment de NVIDIA, je suppose? Ce que j’obtiens en faisant le man nv me permet de voir le résultat par rapport aux pilotes propriétaires ou non propriétaires, dans ce cas? J’avais cru, pour être honnête, que les pilotes nv était des propriétaires. Est-ce justement ce qui distingue les pilotes “nv” des “nvidia”? (voilà ce qui arrive quand on a eu que des portables dôtés de chipset graphiques : on passe totalement à coté de ce type de problématiques… lol - bon encore une bonne occaze d’apprendre, c’est pas plus mal).
Ensuite, Pour info perso et y voir plus claire : je suppose que “(EE) NV(0): No display devices found” signifie que je n’ai pas de driver, n’est ce pas? Dans ce cas, je vais vraiment devoir recompiler. Par contre, pourquoi, à mon install, j’avais une interface dans ce cas? Le serveur utilisait donc autre chose que la carte graphique pour l’install? Sur les carte mère permettant l’utilisation d’une carte graphique fille, il y a tout de même un chipset intégré, peut-être, qui serait utilisé, par défaut, par le système pour l’interface graphique? N’étant pas très “matériel”, je n’en suis pas totalement certain, cependant, ça expliquerait déjà une partie du pourquoi du comment.
Et comme le disent si bien les utilisateurs : à l’endroit ou on me demande de taper mon mot de passe, je dois taper mon mot de passe? (question existentielle… ok, je sors… je plaisante, bien entendu).
Thx,
Chris
nv c’est le pilote générique libre qui ne fournit donc pas l’accélération 3D. Le pilote Nvidia est le pilote propriétaire qui, lui, permet d’avoir le 3D. Ta carte 8600GT est supportée sans problème par le pilote Nvidia (voir là : http://us.download.nvidia.com/XFree86/Linux-x86/169.12/README/appendix-a.html) que tu peut installer facilement en suivant le tuto dans Trucs et Astuces : http://forum.debian-fr.org/viewtopic.php?f=8&t=13604
Il n’y a aucun souci pour une utilisation sans 32D de ta carte, utilise le driver VESA (stazndard depuis les années 90), tu mets vesa au lieu de nv dans le Xorg.conf.
32 dimensions ? Je me demande à quoi peut ressembler un écran fait pour. Ca prend pas trop de place ?
:laughing:
lol 32D - C’est impressionnant ce que peut faire NVIDIA aujourd’hui… La dimension spatio-temporelle est quand même incluse dedans par défaut, rassure-moi? Y a l’acceleration vitesse lumière aussi? (Lol).
Plus sérieusement, merci pour les infos. Je vais faire une petite recherche au sujet de vesa (histoire d’en savoir plus, simplement). En fait, j’aimerais bien me mettre compiz-fusion, histoire de voir la tête que ça a (comme ça, je pourrais travailler avec quatre interfaces en lignes de commandes… Je sais, ça sert à rien, muarf!!! Mais ça me botte et je voudrais voir comment ça tourne). Autrement dit, 3D (au minimum, bien sûr…), je pense. Donc Nvidia, probably.
Thx,
Chris
hi,
Je souhaiterais juste savoir : sur le site de nvidia, on peut trouver un fichier .run pour pilotes de driver série 8x verson 64bits. D’après le tuto de Debianhadic, faut le lourder si on la installé (ce que je n’ai pas encore fait).
Why? Ca ne marche pas?
Chris
