Bien… il y a une petite avancée.
J’ai commenté les sources etch pour ne garder provisoirement que la source sid, dégagé xserver-xorg, et fait un aptitutde reinstall.
Maintenant, j’ai le module manquant!!
sh-3.1# dpkg -S libwfb.so
xserver-xorg-core: /usr/lib/xorg/modules/libwfb.so
Par contre, ce n’est pas terminé :
sh-3.1# startx
xauth: creating new authority file /home/Masteradm01/.serverauth.21168
X: warning; process set to priority -1 instead of requested priority 0
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-5)
Current Operating System: Linux Monstre 2.6.24-etchnhalf.1-amd64 #1 SMP Mon Jul 21 10:36:02 UTC 2008 x86_64
Build Date: 26 August 2008 06:07:42PM
Before reporting problems, check [wiki.x.org](http://wiki.x.org)
Module Loader present
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Sep 12 09:23:30 2008
(==) Using config file: “/etc/X11/xorg.conf”
(II) Module “ddc” already built-in
(II) Module “ramdac” already built-in
expected keysym, got XF86KbdLightOnOff: line 70 of pc
expected keysym, got XF86KbdBrightnessDown: line 71 of pc
expected keysym, got XF86KbdBrightnessUp: line 72 of pc
expected keysym, got circumflex: line 257 of fr
The XKEYBOARD keymap compiler (xkbcomp) reports:
Error: No Symbols named “fr” in the include file "fr"
Exiting
Abandoning symbols file "default"
Errors from xkbcomp are not fatal to the X server
Could not init font path element /usr/share/fonts/X11/Type1, removing from list!
Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueTyp e, removing from list!
Et ça stoppe là.
Il manque sans doute encore quelque chose… Un problème de polices, peut-être… Je vais chercher.
