pour le memtest, je viens de penser  à une chose : on le sélectionne au boot, mais je n’ai pas accès au serveur à ce moment là. Je ne sais m’y connecter qu’en ssh après son démarrage… j’ai pas de lcd à coller dessus pour le boot…
Alors le dmesg
dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.23-olimex (root@runner-cpbkaozn-project-1-concurrent-0) (arm-linux-gnueabihf-gcc (Debian 8.3.0-2) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #110018 SMP Wed Mar 17 11:01:34 UTC 2021
    [    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Olimex A20-OLinuXino-LIME2
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000040000000-0x000000006fffffff]
    [    0.000000]   HighMem  [mem 0x0000000070000000-0x000000007fffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
    [    0.000000] On node 0 totalpages: 262144
    [    0.000000]   Normal zone: 1728 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    [    0.000000] percpu: Embedded 20 pages/cpu s50444 r8192 d23284 u81920
    [    0.000000] pcpu-alloc: s50444 r8192 d23284 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260416
    [    0.000000] Kernel command line: root=PARTUUID=b71fb137-01 rootwait console=ttyS0,115200 panic=10 loglevel=4
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] allocated 1048576 bytes of page_ext
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 914044K/1048576K available (10240K kernel code, 1208K rwdata, 2400K rodata, 1024K init, 300K bss, 36228K reserved, 98304K cma-reserved, 262144K highmem)
    [    0.000000] random: get_random_u32 called from __kmem_cache_create+0x30/0x3d8 with crng_init=0
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] ftrace: allocating 35253 entries in 69 pages
    [    0.000000] ftrace: allocated 69 pages with 3 groups
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
    [    0.000000] 	Rude variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    [    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    [    0.000023] Switching to timer-based delay loop, resolution 41ns
    [    0.000669] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.001080] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns
    [    0.001477] Console: colour dummy device 80x30
    [    0.001559] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    [    0.001580] pid_max: default: 32768 minimum: 301
    [    0.001949] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.001970] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.003376] CPU: Testing write buffer coherency: ok
    [    0.003945] /cpus/cpu@0 missing clock-frequency property
    [    0.003991] /cpus/cpu@1 missing clock-frequency property
    [    0.004010] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.005045] Setting up static identity map for 0x40100000 - 0x40100060
    [    0.005239] rcu: Hierarchical SRCU implementation.
    [    0.006147] smp: Bringing up secondary CPUs ...
    [    0.017229] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.017453] smp: Brought up 1 node, 2 CPUs
    [    0.017471] SMP: Total of 2 processors activated (96.00 BogoMIPS).
    [    0.017479] CPU: All CPU(s) started in HYP mode.
    [    0.017484] CPU: Virtualization extensions available.
    [    0.018643] devtmpfs: initialized
    [    0.029585] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
    [    0.029935] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.029967] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.034568] pinctrl core: initialized pinctrl subsystem
    [    0.036258] NET: Registered protocol family 16
    [    0.038107] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.038999] audit: initializing netlink subsys (disabled)
    [    0.039409] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
    [    0.040157] thermal_sys: Registered thermal governor 'fair_share'
    [    0.040171] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.040179] thermal_sys: Registered thermal governor 'step_wise'
    [    0.040584] cpuidle: using governor ladder
    [    0.040622] cpuidle: using governor menu
    [    0.040926] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.040937] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.085301] iommu: Default domain type: Translated
    [    0.085934] SCSI subsystem initialized
    [    0.086323] libata version 3.00 loaded.
    [    0.086646] usbcore: registered new interface driver usbfs
    [    0.086709] usbcore: registered new interface driver hub
    [    0.086769] usbcore: registered new device driver usb
    [    0.087209] pps_core: LinuxPPS API ver. 1 registered
    [    0.087220] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.087244] PTP clock support registered
    [    0.088138] Advanced Linux Sound Architecture Driver Initialized.
    [    0.089668] clocksource: Switched to clocksource arch_sys_counter
    [    0.149758] VFS: Disk quotas dquot_6.6.0
    [    0.149916] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.161344] NET: Registered protocol family 2
    [    0.162584] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [    0.162669] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.162751] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.162879] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.163042] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.163116] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.163449] NET: Registered protocol family 1
    [    0.164095] Trying to unpack rootfs image as initramfs...
    [    0.817109] Freeing initrd memory: 8812K
    [    0.817622] hw perfevents: no interrupt-affinity property for /pmu, guessing.
    [    0.818277] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
    [    0.820077] Initialise system trusted keyrings
    [    0.820521] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.827088] zbud: loaded
    [    0.949173] Key type asymmetric registered
    [    0.949197] Asymmetric key parser 'x509' registered
    [    0.949290] bounce: pool size: 64 pages
    [    0.949371] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    0.949704] io scheduler mq-deadline registered
    [    0.949719] io scheduler kyber registered
    [    0.950086] io scheduler bfq registered
    [    0.951758] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
    [    0.956297] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
    [    1.036487] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
    [    1.039329] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
    [    1.040637] printk: console [ttyS0] disabled
    [    1.040768] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 58, base_baud = 1500000) is a 16550A
    [    1.057610] printk: console [ttyS0] enabled
    [    1.058580] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
    [    1.059876] 1c28c00.serial: ttyS1 at MMIO 0x1c28c00 (irq = 59, base_baud = 1500000) is a 16550A
    [    1.061615] 1c29000.serial: ttyS2 at MMIO 0x1c29000 (irq = 60, base_baud = 1500000) is a 16550A
    [    1.062597] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator
    [    1.063756] 1c29400.serial: ttyS3 at MMIO 0x1c29400 (irq = 61, base_baud = 1500000) is a 16550A
    [    1.065433] 1c29800.serial: ttyS4 at MMIO 0x1c29800 (irq = 62, base_baud = 1500000) is a 16550A
    [    1.067241] 1c29c00.serial: ttyS5 at MMIO 0x1c29c00 (irq = 63, base_baud = 1500000) is a 16550A
    [    1.068616] STM32 USART driver initialized
    [    1.080036] brd: module loaded
    [    1.090264] loop: module loaded
    [    1.091758] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
    [    1.092043] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
    [    1.094949] spi-nor spi0.0: w25q128 (16384 Kbytes)
    [    1.100262] libphy: Fixed MDIO Bus: probed
    [    1.101521] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found
    [    1.101540] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found
    [    1.101915] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
    [    1.101935] sun7i-dwmac 1c50000.ethernet: no reset control found
    [    1.101982] sun7i-dwmac 1c50000.ethernet: no regulator found
    [    1.102418] sun7i-dwmac 1c50000.ethernet: Version ID not available
    [    1.102442] sun7i-dwmac 1c50000.ethernet: 	DWMAC1000
    [    1.102453] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
    [    1.102463] sun7i-dwmac 1c50000.ethernet: Normal descriptors
    [    1.102471] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
    [    1.103164] libphy: stmmac: probed
    [    1.129285] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.129306] ehci-platform: EHCI generic platform driver
    [    1.130088] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    1.130142] ohci-platform: OHCI generic platform driver
    [    1.131305] usbcore: registered new interface driver usb-storage
    [    1.133189] sunxi-rtc 1c20d00.rtc: registered as rtc0
    [    1.133268] sunxi-rtc 1c20d00.rtc: setting system clock to 2021-03-20T10:34:43 UTC (1616236483)
    [    1.133534] i2c /dev entries driver
    [    1.135276] axp20x-i2c 0-0034: AXP20x variant AXP209 found
    [    1.143266] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0
    [    1.152601] vdd-rtc: supplied by regulator-dummy
    [    1.153933] avcc: supplied by regulator-dummy
    [    1.154536] vddio-csi0: Bringing 2800000uV into 3300000-3300000uV
    [    1.156149] vddio-csi0: supplied by regulator-dummy
    [    1.156453] vddio-csi1: supplied by regulator-dummy
    [    1.157209] ldo5: supplied by regulator-dummy
    [    1.158014] vdd-cpu: supplied by regulator-dummy
    [    1.158814] vdd-int-dll: supplied by regulator-dummy
    [    1.160423] axp20x-i2c 0-0034: AXP20X driver loaded
    [    1.166240] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
    [    1.167125] sdhci: Secure Digital Host Controller Interface driver
    [    1.167135] sdhci: Copyright(c) Pierre Ossman
    [    1.167141] Synopsys Designware Multimedia Card Interface Driver
    [    1.168077] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.169593] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
    [    1.171232] sunxi-mmc 1c0f000.mmc: Got CD GPIO
    [    1.171649] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.171792] hid: raw HID events driver (C) Jiri Kosina
    [    1.171981] usbcore: registered new interface driver usbhid
    [    1.171992] usbhid: USB HID core driver
    [    1.175391] Initializing XFRM netlink socket
    [    1.176182] NET: Registered protocol family 10
    [    1.194346] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
    [    1.236592] Segment Routing with IPv6
    [    1.236745] NET: Registered protocol family 17
    [    1.236795] NET: Registered protocol family 15
    [    1.237028] 8021q: 802.1Q VLAN Support v1.8
    [    1.237123] Key type dns_resolver registered
    [    1.237270] Registering SWP/SWPB emulation handler
    [    1.237855] registered taskstats version 1
    [    1.237875] Loading compiled-in X.509 certificates
    [    1.238022] zswap: loaded using pool lzo/zbud
    [    1.239018] Key type ._fscrypt registered
    [    1.239034] Key type .fscrypt registered
    [    1.239040] Key type fscrypt-provisioning registered
    [    1.268149] Key type encrypted registered
    [    1.289959] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
    [    1.290223] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
    [    1.345712] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP
    [    1.345780] ahci-sunxi 1c18000.sata: SSS flag set, parallel bus scan disabled
    [    1.345818] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    1.345835] ahci-sunxi 1c18000.sata: flags: ncq sntf stag pm led clo only pio slum part ccc
    [    1.347266] scsi host0: ahci-sunxi
    [    1.347757] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 47
    [    1.348897] ehci-platform 1c14000.usb: EHCI Host Controller
    [    1.348967] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
    [    1.349471] ehci-platform 1c14000.usb: irq 42, io mem 0x01c14000
    [    1.361706] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
    [    1.362038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    1.362054] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.362063] usb usb1: Product: EHCI Host Controller
    [    1.362071] usb usb1: Manufacturer: Linux 5.10.23-olimex ehci_hcd
    [    1.362080] usb usb1: SerialNumber: 1c14000.usb
    [    1.363064] hub 1-0:1.0: USB hub found
    [    1.363140] hub 1-0:1.0: 1 port detected
    [    1.364683] ehci-platform 1c1c000.usb: EHCI Host Controller
    [    1.364724] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
    [    1.365130] ehci-platform 1c1c000.usb: irq 48, io mem 0x01c1c000
    [    1.377696] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
    [    1.378012] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    1.378027] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.378037] usb usb2: Product: EHCI Host Controller
    [    1.378046] usb usb2: Manufacturer: Linux 5.10.23-olimex ehci_hcd
    [    1.378054] usb usb2: SerialNumber: 1c1c000.usb
    [    1.378916] hub 2-0:1.0: USB hub found
    [    1.379019] hub 2-0:1.0: 1 port detected
    [    1.380540] ohci-platform 1c14400.usb: Generic Platform OHCI controller
    [    1.380581] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
    [    1.380953] ohci-platform 1c14400.usb: irq 43, io mem 0x01c14400
    [    1.441969] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    1.441988] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.441998] usb usb3: Product: Generic Platform OHCI controller
    [    1.442007] usb usb3: Manufacturer: Linux 5.10.23-olimex ohci_hcd
    [    1.442015] usb usb3: SerialNumber: 1c14400.usb
    [    1.442884] hub 3-0:1.0: USB hub found
    [    1.442961] hub 3-0:1.0: 1 port detected
    [    1.444460] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
    [    1.444503] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
    [    1.444965] ohci-platform 1c1c400.usb: irq 49, io mem 0x01c1c400
    [    1.505968] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
    [    1.505990] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.506000] usb usb4: Product: Generic Platform OHCI controller
    [    1.506009] usb usb4: Manufacturer: Linux 5.10.23-olimex ohci_hcd
    [    1.506018] usb usb4: SerialNumber: 1c1c400.usb
    [    1.506891] hub 4-0:1.0: USB hub found
    [    1.506971] hub 4-0:1.0: 1 port detected
    [    1.508566] usb_phy_generic usb_phy_generic.0.auto: supply vcc not found, using dummy regulator
    [    1.510015] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
    [    1.510057] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5
    [    1.510464] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [    1.510480] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.510489] usb usb5: Product: MUSB HDRC host driver
    [    1.510498] usb usb5: Manufacturer: Linux 5.10.23-olimex musb-hcd
    [    1.510507] usb usb5: SerialNumber: musb-hdrc.1.auto
    [    1.511360] hub 5-0:1.0: USB hub found
    [    1.511436] hub 5-0:1.0: 1 port detected
    [    1.515024] ALSA device list:
    [    1.515044]   No soundcards found.
    [    1.664190] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    [    1.664426] ata1.00: ATA-11: SPCC Solid State Disk, SBFM61.3, max UDMA/133
    [    1.664441] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 32)
    [    1.664628] ata1.00: configured for UDMA/133
    [    1.665331] scsi 0:0:0:0: Direct-Access     ATA      SPCC Solid State 61.3 PQ: 0 ANSI: 5
    [    1.666582] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [    1.667012] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
    [    1.667112] sd 0:0:0:0: [sda] Write Protect is off
    [    1.667127] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [    1.667247] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [    1.668794]  sda: sda1
    [    1.670667] sd 0:0:0:0: [sda] Attached SCSI disk
    [    1.674802] Freeing unused kernel memory: 1024K
    [    1.681940] Run /init as init process
    [    1.681950]   with arguments:
    [    1.681956]     /init
    [    1.681961]   with environment:
    [    1.681966]     HOME=/
    [    1.681971]     TERM=linux
    [    2.977184] axp20x-gpio axp20x-gpio: DMA mask not set
    [    2.978239] random: fast init done
    [    2.980696] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
    [    3.799986] process '/usr/bin/fstype' started with executable stack
    [    5.798338] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [    6.212598] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [    6.213390] systemd[1]: Detected architecture arm.
    [    6.264261] systemd[1]: Set hostname to <crust.ovh>.
    [    7.195584] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
    [    7.198052] systemd[1]: /lib/systemd/system/dovecot.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/dovecot/master.pid → /run/dovecot/master.pid; please update the unit file accordingly.
    [    7.286184] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.307519] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.308141] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    7.325985] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.328915] systemd[1]: Listening on Syslog Socket.
    [    7.347327] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    7.366540] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    7.387020] systemd[1]: Listening on Journal Socket (/dev/log).
    [    7.796576] g_serial gadget: Gadget Serial v2.4
    [    7.796603] g_serial gadget: g_serial ready
    [    8.117741] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro
    [    8.338094] Adding 2097148k swap on /swapfile.  Priority:-2 extents:3 across:5046268k SSFS
    [    9.038189] systemd-journald[207]: Received request to flush runtime journal from PID 1
    [   10.331059] pwm-backlight backlight: supply power not found, using dummy regulator
    [   10.356210] pwm-backlight backlight: supply power not found, using dummy regulator
    [   10.929905] pwm-backlight backlight: supply power not found, using dummy regulator
    [   10.942337] mc: Linux media interface: v0.10
    [   10.978005] sun4i-ss 1c15000.crypto-engine: Die ID 0
    [   11.075276] videodev: Linux video capture interface: v2.00
    [   11.114752] pwm-backlight backlight: supply power not found, using dummy regulator
    [   11.257334] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
    [   11.274707] cedrus 1c0e000.video-codec: Device registered as /dev/video0
    [   11.370099] pwm-backlight backlight: supply power not found, using dummy regulator
    [   11.393358] debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present!
    [   11.541398] CAN device driver interface
    [   11.580576] sun4i_can 1c2bc00.can: device registered (base=(ptrval), irq=67)
    [   11.620819] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
    [   11.620913] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
    [   11.620982] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
    [   11.621052] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
    [   11.651725] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
    [   11.652690] lima 1c40000.gpu: bus rate = 300000000
    [   11.652714] lima 1c40000.gpu: mod rate = 384000000
    [   11.653970] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 0
    [   11.668127] lcd_olinuxino 2-0050: error reading from device at 00
    [   11.797024] at24 1-0050: supply vcc not found, using dummy regulator
    [   11.832805] at24 1-0050: 2048 byte 24c16 EEPROM, writable, 16 bytes/write
    [   11.950857] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
    [   11.957790] axp20x-adc axp20x-adc: DMA mask not set
    [   11.973092] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set
    [   16.167276] random: crng init done
    [   16.167311] random: 7 urandom warning(s) missed due to ratelimiting
    [   22.220197] sun7i-dwmac 1c50000.ethernet eth0: PHY [stmmac-0:01] driver [Micrel KSZ9031 Gigabit PHY] (irq=POLL)
    [   22.229798] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
    [   22.229829] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
    [   22.229845] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
    [   22.229857] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
    [   22.230925] sun7i-dwmac 1c50000.ethernet eth0: configuring for phy/rgmii link mode
    [   25.322834] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   25.322909] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   31.721504] vcc3v0: disabling
    [   31.721537] vcc5v0: disabling
    [   31.721557] usb0-vbus: disabling
    [22760.849071] hrtimer: interrupt took 265803 ns
    [103225.724734] Adding 1048572k swap on /swap_flarum.  Priority:-3 extents:3 across:1130496k SSFS
