Il faut configurer les UID/GID de façon identique sur les deux distributions pour éviter les problèmes que tu cites précédemment.
Extrait du manuel de Redhat, valable également pour Debian. Cet extrait est plutôt focalisé sur le réseau, mais c’est également valable pour un système avec des partitions partagées :
[quote]UIDs and GIDs must be globally unique within your organization if you intend to share files and resources over a network. Otherwise, whatever access controls you put in place will fail to work properly, as they are based on UIDs and GIDs, not usernames and group names.
Specifically, if the /etc/passwd and /etc/group files on a file server and a user’s workstation differ in the UIDs or GIDs they contain, improper application of permissions can lead to security issues.
For example, if user juan has a UID of 500 on a desktop computer, files juan creates on a file server will be created with owner UID 500. However, if user bob logs in locally to the file server (or even some other computer), and bob’s account also has a UID of 500, bob will have full access to juan’s files, and vice versa.
Therefore, UID and GID collisions are to be avoided at all costs.[/quote]
redhat.com/docs/manuals/linu … lspec.html
