munmap(0xb616f000, 4096) = 0
open("/usr/share/alsa/pcm/surround41.conf", O_RDONLY) = 19
fstat64(19, {st_mode=S_IFREG|0644, st_size=893, …}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb616f000
read(19, “#\n# Hardware output from 4.1 sp”…, 4096) = 893
read(19, “”, 4096) = 0
close(19) = 0
open("/usr/share/alsa/pcm/surround50.conf", O_RDONLY) = 19
fstat64(19, {st_mode=S_IFREG|0644, st_size=896, …}) = 0
read(19, “#\n# Hardware output from 5.0 sp”…, 4096) = 896
close(19) = 0
open("/usr/share/alsa/pcm/surround51.conf", O_RDONLY) = 19
fstat64(19, {st_mode=S_IFREG|0644, st_size=783, …}) = 0
read(19, “#\n# Hardware output from 5.1 sp”…, 4096) = 783
close(19) = 0
read(17, “annel 1 }\n\t]\n}\n\n<confdir:pcm/iec”…, 4096) = 1831
open("/usr/share/alsa/pcm/iec958.conf", O_RDONLY) = 19
fstat64(19, {st_mode=S_IFREG|0644, st_size=1030, …}) = 0
read(19, “#\n# Hardware output from iec958”…, 4096) = 1030
close(19) = 0
read(17, “”, 4096) = 0
close(17) = 0
munmap(0xb6b8b000, 4096) = 0
open("/dev/snd/controlC1", O_RDONLY) = 17
close(17) = 0
stat64("/usr/share/alsa/alsa.conf", {st_mode=S_IFREG|0644, st_size=7701, …}) = 0
close(17) = 0
open("/dev/snd/controlC1", O_RDWR) = 17
ioctl(17, USBDEVFS_CONTROL, 0xbfc08148) = 0
ioctl(17, UI_DEV_CREATE, 0xbfc08120) = 0
close(17) = 0
access("/usr/share/alsa/cards/MPU-401.conf", R_OK) = -1 ENOENT (No such file or directory)
read(3, “\0346\332\234\37\0\200\1(\0\0\0\276\275\3403\1\0\0\0\1”…, 32) = 32
read(3, “\0346\332\234\37\0\200\1\372\0\0\0\276\275\3403\1\0\0\0”…, 32) = 32
read(3, “\0346\332\234\37\0\200\1C\0\0\0\276\275\3403\1\0\0\0\1”…, 32) = 32
read(3, “\0346\332\234\37\0\200\1%\0\0\0\276\275\3403\1\0\0\0\1”…, 32) = 32
read(3, “\0346\332\234\37\0\200\1\376\0\0\0\276\275\3403\1\0\0\0”…, 32) = 32
read(3, “\0346\332\234\37\0\200\1’\0\0\0\276\275\3403\1\0\0\0\1”…, 32) = 32
read(3, “\0346\332\234\37\0\200\1\377\0\0\0\276\275\3403\1\0\0\0”…, 32) = 32
read(3, “\1\1\334\234\0\0\0\0\36\0\240\0\37\0\200\1\0\0\0\0(j\253”…, 32) = 32
access(“MARK: [main.c main 382] END mainloop”, F_OK) = -1 ENOENT (No such file or directory)
gettimeofday({1181986373, 497626}, NULL) = 0
gettimeofday({1181986373, 497958}, NULL) = 0
gettimeofday({1181986373, 498269}, NULL) = 0
gettimeofday({1181986373, 498566}, NULL) = 0
gettimeofday({1181986373, 498855}, NULL) = 0
gettimeofday({1181986373, 499155}, NULL) = 0
gettimeofday({1181986373, 499491}, NULL) = 0
gettimeofday({1181986373, 499806}, NULL) = 0
gettimeofday({1181986373, 500111}, NULL) = 0
gettimeofday({1181986373, 500413}, NULL) = 0
gettimeofday({1181986373, 500718}, NULL) = 0
gettimeofday({1181986373, 501030}, NULL) = 0
gettimeofday({1181986373, 501330}, NULL) = 0
gettimeofday({1181986373, 501637}, NULL) = 0
gettimeofday({1181986373, 501943}, NULL) = 0
close(21) = 0
brk(0x8c18000) = 0x8c18000
close(20) = 0
brk(0x8b5f000) = 0x8b5f000
gettimeofday({1181986373, 509553}, NULL) = 0
gettimeofday({1181986373, 509915}, NULL) = 0
gettimeofday({1181986373, 510238}, NULL) = 0
gettimeofday({1181986373, 510511}, NULL) = 0
gettimeofday({1181986373, 510762}, NULL) = 0
gettimeofday({1181986373, 511020}, NULL) = 0
gettimeofday({1181986373, 511252}, NULL) = 0
gettimeofday({1181986373, 511580}, NULL) = 0
gettimeofday({1181986373, 511820}, NULL) = 0
gettimeofday({1181986373, 511865}, NULL) = 0
access(“MARK: [main.c main 400] END starting rhythmbox”, F_OK) = -1 ENOENT (No such file or directory)
writev(12, [{“GIOP\1\2\1\5\0\0\0\0”, 12}], 1) = 12
close(12) = 0
writev(10, [{“GIOP\1\2\1\5\0\0\0\0”, 12}], 1) = 12
close(10) = 0
close(9) = 0
close(8) = 0
unlink("/tmp/orbit-syrus/linc-11f6-0-26db33cd5de7") = 0
close(11) = 0
exit_group(0) = ?
