ma carte mere est une msi MS-6712(v1.X) ATX mainborad KT4V . processeur AMD Atlhon xp 1250 mhz . Carte Graphique GeForce 6600GT twintech .
copie-moi ici, stp, ce que te donne un :
lspci | grep -i via
enfin, si tu as envie qu’on vérifisse !
[quote]thomas@debian:~$ lspci | grep -i via
00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8235 PCI Bridge
00:06.0 Ethernet controller: VIA Technologies, Inc. VT6105 [Rhine-III] (rev 86)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80)
00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
thomas@debian:~$
par contre j ai reessayer d installer les driver NVIDIA par synaptic : nvidia-kernel-2.618-4-k7 / nvidia-kernel-commom / nvidia-kernel-legacy-source / nvidia-settings / nvidia-xconfig / xserveur-xorg-video-nv . le nouveaux probleme que j ai ses que mon pc redemare normalement mais j ai pas de nvidia dans mon fichier xorg . je suis en vesa et ma carte nes pas reconnue
essayes nvidia-xconfig (en root)
sa ma rajouter NVIDIA mes pas la carte [quote]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildd@saens) Sat May 12 22:20:45 UTC 2007
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen “Default Screen” 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section “Files”
# path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Monitor"
Identifier "AL1715"
Option "DPMS"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "AL1715"
DefaultDepth 24
Option “NvAGP” "0"
SubSection "Display"
Depth 1
Modes “1280x1024” “1024x768” “832x624” “800x600” “720x400” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
[quote=“paladin”]sa ma rajouter NVIDIA mes pas la carte (…)[/quote]Qu’est ce que tu veux dire ?
c’est normal que ca te mette en nvidia puisque ta carte EST une nvidia…
Sinon, quel est le problême ? Le fil concerne bien l’install des pilotes nvidia, non ?
bon en faite oui ses le meme sujet . j avais j uste installer les drivers par synaptic mais pas xgl car il ne voulais pas l installer . ce matin j ai pue l installer . j ai redemarrer et encore ecrant noir le probleme ses que , a chaque foi . je me retrouve avec un ecrant noir
j ai pris la methode decrite sur le forum sa marche pas , par envy voila mon poste : forum.debian-fr.org/viewtopic.php?t=7752 idem ecrant noir et par synaptic pareil j ai beaux lire tous ce que je trouve ici mais rien ne marche pour moi
je ses pas, si ses par ce que . ma carte est une pci-express . ou si je fait pas les manipes comme il faut
j ai fait le grand saut de windows a linux en octobre 2006 . avant j etais en dual boot avec windows et franchement linux et la ligne de commande cetais du chinoie pour moi
et la je nage completement , mais je deséspere pas de trouver cette fichue solution pour la faire marcher cette carte . si les autres y arrive je devrais bien y arriver
[quote=“paladin”][quote]thomas@debian:~$ lspci | grep -i via
thomas@debian:~$
[/quote][/quote]
Bon, c’est bien ce que je supposais ; tu as le support natif AGPART - VIA KT400 - par le kernel.
Ca peut rentrer en conflit avec le support AGP nVidia.
Tu ne ns a pas dit si de mettre 'Option “NvAGP” “0” te modifiait la donne ?!
[quote] “NvAGP” “0” [/quote] sa ne donne rien du tous [quote]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
package.
EndSection
Section “Files”
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Monitor"
Identifier "AL1715"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Monitor "AL1715"
DefaultDepth 24
Option “NvAGP” "0"
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
[/quote] j ai mis tous sa ici : forum.debian-fr.org/viewtopic.php?t=7752
L’option NvAGP se met dans la section monitor et non ailleurs …
après tu test à ou mieux à 2 !
[quote=“PengouinPdt”]L’option NvAGP se met dans la section monitor et non ailleurs …
après tu test à ou mieux à 2 ![/quote] a bas , je les changer mais pas la nom plus. j ai mis sa dans device
bon bas je vais rechanger sa
Screen ou device comme tu veux, usuellement c’est un paramètre nvidia donc mis plutôt dans cette section:
[quote]Appendix D. X Config Options
The following driver options are supported by the NVIDIA X driver. They may be specified either in the Screen or Device sections of the X config file.
X Config Options
Option “NvAGP” “integer”
Configure AGP support. Integer argument can be one of:
Value Behavior
0 disable AGP
1 use NVIDIA's internal AGP support, if possible
2 use AGPGART, if possible
3 use any AGP support (try AGPGART, then NVIDIA's AGP)
Please note that NVIDIA's internal AGP support cannot work if AGPGART is either statically compiled into your kernel or is built as a module and loaded into your kernel. [/quote]
milles excuses, j’ai écrit monitor alors que je voulais dire device …
par contre, concernant screen, j’avais pas fait gaffe.
Sorry.
