voici
NoThing:/home/softreaver# ifconfig
eth0 Lien encap:UNSPEC HWaddr 00-03-0D-53-25-51-B3-FB-00-00-00-00-00-00-00-00
inet adr:183.132.122.89 Bcast:183.132.255.255 Masque:255.255.0.0
TX packets:19 errors:110 dropped:110 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:2571 (2.5 KiB)
eth1 Lien encap:Ethernet HWaddr 00:03:0D:18:AB:66
inet adr:192.168.1.3 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::203:dff:fe18:ab66/64 Scope:Lien
RX packets:1133 errors:0 dropped:0 overruns:0 frame:0
TX packets:1173 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:200722 (196.0 KiB) TX bytes:109858 (107.2 KiB)
Interruption:201 Adresse de base:0xd800
lo Lien encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:280 errors:0 dropped:0 overruns:0 frame:0
TX packets:280 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:50362 (49.1 KiB) TX bytes:50362 (49.1 KiB)
sit0 Lien encap:IPv6-dans-IPv4
adr inet6: ::183.132.122.89/96 Scope:Compat
adr inet6: ::127.0.0.1/96 Scope:Inconnu
UP RUNNING NOARP MTU:1480 Metric:1
TX packets:0 errors:105 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
NoThing:/home/softreaver# route
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 eth1
183.132.0.0 * 255.255.0.0 U 0 0 0 eth0
default 192.168.1.1 0.0.0.0 UG 0 0 0 eth1
NoThing:/home/softreaver# traceroute google.fr
traceroute: Warning: google.fr has multiple addresses; using 216.239.59.104
traceroute to google.fr (216.239.59.104), 30 hops max, 40 byte packets
1 192.168.1.1 (192.168.1.1) 5.002 ms 1.342 ms 1.584 ms
2 bas02.bor.as12876.net (212.129.9.91) 37.554 ms 38.254 ms 38.174 ms
3 vlan58.sw3.bor.as12876.net (212.129.15.170) 38.992 ms 38.086 ms 77.958 ms 4 ge-0-0-0-11.bb2.bor.as12876.net (212.129.23.181) 38.015 ms 39.326 ms *
5 so-2-0-0-0.bb1.cou.as12876.net (212.129.8.92) 45.722 ms 46.324 ms 45.265 ms
6 google.FreeIX.net (213.228.3.136) 46.533 ms 46.205 ms 46.475 ms
7 72.14.232.94 (72.14.232.94) 53.478 ms 53.414 ms 216.239.49.46 (216.239.49.46) 60.959 ms
8 66.249.95.107 (66.249.95.107) 64.943 ms 209.85.250.216 (209.85.250.216) 68.230 ms 68.439 ms
9 64.233.174.185 (64.233.174.185) 62.988 ms 72.14.232.241 (72.14.232.241) 68.358 ms 64.233.174.185 (64.233.174.185) 63.429 ms
10 216.239.49.126 (216.239.49.126) 66.463 ms 216.239.49.114 (216.239.49.114) 70.881 ms 66.493 ms
11 gv-in-f104.google.com (216.239.59.104) 64.275 ms 68.875 ms 68.846 ms
En revanche pour la commande ping google.fr c’est assés bizar, car la commande semble ne jamais s’arrêter, j’ais deut débrancher le cable.
voici un éxtrait de se que j’ais eu :
NoThing:/home/softreaver# ping google.fr
PING google.fr (66.249.93.104) 56(84) bytes of data.
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=1 ttl=244 time=66.3 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=2 ttl=244 time=64.8 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=3 ttl=244 time=63.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=4 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=5 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=6 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=7 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=8 ttl=244 time=64.3 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=9 ttl=244 time=65.0 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=10 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=11 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=12 ttl=244 time=63.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=13 ttl=244 time=64.8 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=14 ttl=244 time=65.0 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=15 ttl=244 time=64.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=16 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=17 ttl=244 time=63.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=18 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=19 ttl=244 time=65.0 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=20 ttl=244 time=65.0 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=21 ttl=244 time=65.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=22 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=23 ttl=244 time=63.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=24 ttl=244 time=64.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=25 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=26 ttl=244 time=64.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=27 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=28 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=29 ttl=244 time=64.9 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=30 ttl=244 time=64.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=31 ttl=244 time=63.9 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=32 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=33 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=34 ttl=244 time=64.5 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=35 ttl=244 time=64.8 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=36 ttl=244 time=64.1 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=37 ttl=244 time=64.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=38 ttl=244 time=64.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=39 ttl=244 time=65.4 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=40 ttl=244 time=66.2 ms
64 bytes from ug-in-f104.google.com (66.249.93.104): icmp_seq=41 ttl=244 time=64.4 ms
