J’ai updaté et dist-upgradé ma Sid et je n’ai pas le msg habituel d’erreurs mais un autre :
$ startx
xauth : creating new autority file /home/ricardo/.serverauth.6481
xiinit : server error
De l’aide svp
$ startx
De l’aide svp
le log :
Apr 12 11:49:26 localhost kernel: BIOS-provided physical RAM map:
Apr 12 11:49:26 localhost kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 0000000000100000 - 000000001fffc000 (usable)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 000000001fffc000 - 000000001ffff000 (ACPI data)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 000000001ffff000 - 0000000020000000 (ACPI NVS)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Apr 12 11:49:26 localhost kernel: BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Apr 12 11:49:26 localhost kernel: 0MB HIGHMEM available.
Apr 12 11:49:26 localhost kernel: 511MB LOWMEM available.
Apr 12 11:49:26 localhost kernel: DMI 2.3 present.
Apr 12 11:49:26 localhost kernel: ACPI: PM-Timer IO Port: 0xe408
Apr 12 11:49:26 localhost kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Apr 12 11:49:26 localhost kernel: Processor #0 15:2 APIC version 20
Apr 12 11:49:26 localhost kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Apr 12 11:49:26 localhost kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Apr 12 11:49:26 localhost kernel: IOAPIC[0]: apic_id 2, version 128, address 0xfec00000, GSI 0-23
Apr 12 11:49:26 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl edge)
Apr 12 11:49:26 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 20 low level)
Apr 12 11:49:26 localhost kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
Apr 12 11:49:26 localhost kernel: Using ACPI (MADT) for SMP configuration information
Apr 12 11:49:26 localhost kernel: Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Apr 12 11:49:26 localhost kernel: Built 1 zonelists
Apr 12 11:49:26 localhost kernel: Kernel command line: root=/dev/hdc5 ro
Apr 12 11:49:26 localhost kernel: Enabling fast FPU save and restore... done.
Apr 12 11:49:26 localhost kernel: Enabling unmasked SIMD FPU exception support... done.
Apr 12 11:49:26 localhost kernel: Initializing CPU#0
Apr 12 11:49:26 localhost kernel: PID hash table entries: 2048 (order: 11, 32768 bytes)
Apr 12 11:49:26 localhost kernel: Detected 2533.434 MHz processor.
Apr 12 11:49:26 localhost kernel: Using pmtmr for high-res timesource
Apr 12 11:49:26 localhost kernel: Console: colour VGA+ 80x25
Apr 12 11:49:26 localhost kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Apr 12 11:49:26 localhost kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Apr 12 11:49:26 localhost kernel: Memory: 512200k/524272k available (1408k kernel code, 11532k reserved, 527k data, 144k init, 0k highmem)
Apr 12 11:49:26 localhost kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Apr 12 11:49:26 localhost kernel: Calibrating delay using timer specific routine.. 5072.83 BogoMIPS (lpj=2536419)
Apr 12 11:49:26 localhost kernel: Security Framework v1.0.0 initialized
Apr 12 11:49:26 localhost kernel: SELinux: Disabled at boot.
Apr 12 11:49:26 localhost kernel: Capability LSM initialized
Apr 12 11:49:26 localhost kernel: Mount-cache hash table entries: 512
Apr 12 11:49:26 localhost kernel: CPU: Trace cache: 12K uops, L1 D cache: 8K
Apr 12 11:49:26 localhost kernel: CPU: L2 cache: 512K
Apr 12 11:49:26 localhost kernel: Intel machine check architecture supported.
Apr 12 11:49:26 localhost kernel: Intel machine check reporting enabled on CPU#0.
Apr 12 11:49:26 localhost kernel: CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
Apr 12 11:49:26 localhost kernel: CPU0: Thermal monitoring enabled
Apr 12 11:49:26 localhost kernel: CPU: Intel(R) Pentium(R) 4 CPU 2.53GHz stepping 04
Apr 12 11:49:26 localhost kernel: Checking 'hlt' instruction... OK.
Apr 12 11:49:26 localhost kernel: ENABLING IO-APIC IRQs
Apr 12 11:49:26 localhost kernel: ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Apr 12 11:49:26 localhost kernel: checking if image is initramfs... it is
Apr 12 11:49:26 localhost kernel: Freeing initrd memory: 4258k freed
Apr 12 11:49:26 localhost kernel: NET: Registered protocol family 16
Apr 12 11:49:26 localhost kernel: ACPI: bus type pci registered
Apr 12 11:49:26 localhost kernel: PCI: PCI BIOS revision 2.10 entry at 0xf11b0, last bus=1
Apr 12 11:49:26 localhost kernel: PCI: Using configuration type 1
Apr 12 11:49:26 localhost kernel: ACPI: Subsystem revision 20060127
Apr 12 11:49:26 localhost kernel: ACPI: Interpreter enabled
Apr 12 11:49:26 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *9
Apr 12 11:49:26 localhost kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Apr 12 11:49:26 localhost kernel: ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Apr 12 11:49:26 localhost kernel: Enabling SiS 96x SMBus.
Apr 12 11:49:26 localhost kernel: PCI: Ignoring BAR0-3 of IDE controller 0000:00:02.5
Apr 12 11:49:26 localhost kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Apr 12 11:49:26 localhost kernel: pnp: PnP ACPI init
Apr 12 11:49:26 localhost kernel: pnp: PnP ACPI: found 16 devices
Apr 12 11:49:26 localhost kernel: PnPBIOS: Disabled by ACPI PNP
Apr 12 11:49:26 localhost kernel: PCI: Using ACPI for IRQ routing
Apr 12 11:49:26 localhost kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Apr 12 11:49:26 localhost kernel: pnp: 00:02: ioport range 0xe400-0xe47f could not be reserved
Apr 12 11:49:26 localhost kernel: pnp: 00:02: ioport range 0xe480-0xe4ff has been reserved
Apr 12 11:49:26 localhost kernel: pnp: 00:02: ioport range 0xe600-0xe61f has been reserved
Apr 12 11:49:26 localhost kernel: pnp: 00:02: ioport range 0x480-0x48f has been reserved
Apr 12 11:49:26 localhost kernel: pnp: 00:0f: ioport range 0x295-0x296 has been reserved
Apr 12 11:49:26 localhost kernel: PCI: Bridge: 0000:00:01.0
Apr 12 11:49:26 localhost kernel: IO window: disabled.
Apr 12 11:49:26 localhost kernel: MEM window: d6000000-d7ffffff
Apr 12 11:49:26 localhost kernel: PREFETCH window: dff00000-febfffff
Apr 12 11:49:26 localhost kernel: Simple Boot Flag at 0x3a set to 0x1
Apr 12 11:49:26 localhost kernel: audit: initializing netlink socket (disabled)
Apr 12 11:49:26 localhost kernel: audit(1144842534.239:1): initialized
Apr 12 11:49:26 localhost kernel: VFS: Disk quotas dquot_6.5.1
Apr 12 11:49:26 localhost kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Apr 12 11:49:26 localhost kernel: Initializing Cryptographic API
Apr 12 11:49:26 localhost kernel: io scheduler noop registered
Apr 12 11:49:26 localhost kernel: io scheduler anticipatory registered (default)
Apr 12 11:49:26 localhost kernel: io scheduler deadline registered
Apr 12 11:49:26 localhost kernel: io scheduler cfq registered
Apr 12 11:49:26 localhost kernel: isapnp: Scanning for PnP cards...
Apr 12 11:49:26 localhost kernel: isapnp: No Plug & Play device found
Apr 12 11:49:26 localhost kernel: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
Apr 12 11:49:26 localhost kernel: PNP: PS/2 controller doesn't have AUX irq; using default 12
Apr 12 11:49:26 localhost kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Apr 12 11:49:26 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Apr 12 11:49:26 localhost kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Apr 12 11:49:26 localhost kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 12 11:49:26 localhost kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 12 11:49:26 localhost kernel: 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Apr 12 11:49:26 localhost kernel: 00:0c: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Apr 12 11:49:26 localhost kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Apr 12 11:49:26 localhost kernel: NET: Registered protocol family 2
Apr 12 11:49:26 localhost kernel: IP route cache hash table entries: 8192 (order: 3, 32768 bytes)
Apr 12 11:49:26 localhost kernel: TCP established hash table entries: 32768 (order: 5, 131072 bytes)
Apr 12 11:49:26 localhost kernel: TCP bind hash table entries: 32768 (order: 5, 131072 bytes)
Apr 12 11:49:26 localhost kernel: TCP: Hash tables configured (established 32768 bind 32768)
Apr 12 11:49:26 localhost kernel: TCP reno registered
Apr 12 11:49:26 localhost kernel: TCP bic registered
Apr 12 11:49:26 localhost kernel: NET: Registered protocol family 17
Apr 12 11:49:26 localhost kernel: NET: Registered protocol family 8
Apr 12 11:49:26 localhost kernel: NET: Registered protocol family 20
Apr 12 11:49:26 localhost kernel: Using IPI Shortcut mode
Apr 12 11:49:26 localhost kernel: ACPI wakeup devices:
Apr 12 11:49:26 localhost kernel: PCI0 PCI1 PS2K USB0 USB3 USB1 USB2
Apr 12 11:49:26 localhost kernel: ACPI: (supports S0 S1 S4 S5)
Apr 12 11:49:26 localhost kernel: Freeing unused kernel memory: 144k freed
Apr 12 11:49:26 localhost kernel: input: AT Translated Set 2 keyboard as /class/input/input0
Apr 12 11:49:26 localhost kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Apr 12 11:49:26 localhost kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Apr 12 11:49:26 localhost kernel: usbcore: registered new driver usbfs
Apr 12 11:49:26 localhost kernel: usbcore: registered new driver hub
Apr 12 11:49:26 localhost kernel: sis900.c: v1.08.09 Sep. 19 2005
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:04.0[A] -> GSI 19 (level, low) -> IRQ 177
Apr 12 11:49:26 localhost kernel: 0000:00:04.0: Realtek RTL8201 PHY transceiver found at address 1.
Apr 12 11:49:26 localhost kernel: 0000:00:04.0: Using transceiver found at address 1 as default
Apr 12 11:49:26 localhost kernel: eth0: SiS 900 PCI Fast Ethernet at 0x9800, IRQ 177, 00:e0:18:a5:49:94.
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:03.0[A] -> GSI 20 (level, low) -> IRQ 169
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.0: OHCI Host Controller
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 1
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.0: irq 169, io mem 0xd5000000
Apr 12 11:49:26 localhost kernel: usb usb1: configuration #1 chosen from 1 choice
Apr 12 11:49:26 localhost kernel: hub 1-0:1.0: USB hub found
Apr 12 11:49:26 localhost kernel: hub 1-0:1.0: 2 ports detected
Apr 12 11:49:26 localhost kernel: SCSI subsystem initialized
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:03.1[B] -> GSI 21 (level, low) -> IRQ 185
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.1: OHCI Host Controller
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 2
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.1: irq 185, io mem 0xd4800000
Apr 12 11:49:26 localhost kernel: usb usb2: configuration #1 chosen from 1 choice
Apr 12 11:49:26 localhost kernel: hub 2-0:1.0: USB hub found
Apr 12 11:49:26 localhost kernel: hub 2-0:1.0: 2 ports detected
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:03.2[C] -> GSI 22 (level, low) -> IRQ 193
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.2: OHCI Host Controller
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.2: new USB bus registered, assigned bus number 3
Apr 12 11:49:26 localhost kernel: ohci_hcd 0000:00:03.2: irq 193, io mem 0xd4000000
Apr 12 11:49:26 localhost kernel: usb usb3: configuration #1 chosen from 1 choice
Apr 12 11:49:26 localhost kernel: hub 3-0:1.0: USB hub found
Apr 12 11:49:26 localhost kernel: hub 3-0:1.0: 2 ports detected
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:03.3[D] -> GSI 23 (level, low) -> IRQ 201
Apr 12 11:49:26 localhost kernel: ehci_hcd 0000:00:03.3: EHCI Host Controller
Apr 12 11:49:26 localhost kernel: ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 4
Apr 12 11:49:26 localhost kernel: ehci_hcd 0000:00:03.3: irq 201, io mem 0xd3800000
Apr 12 11:49:26 localhost kernel: ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Apr 12 11:49:26 localhost kernel: usb usb4: configuration #1 chosen from 1 choice
Apr 12 11:49:26 localhost kernel: hub 4-0:1.0: USB hub found
Apr 12 11:49:26 localhost kernel: hub 4-0:1.0: 6 ports detected
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:02.3[B] -> GSI 17 (level, low) -> IRQ 209
Apr 12 11:49:26 localhost kernel: ohci1394: fw-host0: Unexpected PCI resource length of 1000!
Apr 12 11:49:26 localhost kernel: ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[209] MMIO=[d5800000-d58007ff] Max Packet=[2048] IR/IT contexts=[4/6]
Apr 12 11:49:26 localhost kernel: SIS5513: IDE controller at PCI slot 0000:00:02.5
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:02.5[A] -> GSI 16 (level, low) -> IRQ 217
Apr 12 11:49:26 localhost kernel: SIS5513: chipset revision 0
Apr 12 11:49:26 localhost kernel: SIS5513: not 100%% native mode: will probe irqs later
Apr 12 11:49:26 localhost kernel: SIS5513: SiS 962/963 MuTIOL IDE UDMA133 controller
Apr 12 11:49:26 localhost kernel: ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hda:pio, hdb:DMA
Apr 12 11:49:26 localhost kernel: ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdc:DMA, hdd:DMA
Apr 12 11:49:26 localhost kernel: usb 2-1: new low speed USB device using ohci_hcd and address 3
Apr 12 11:49:26 localhost kernel: usb 2-1: configuration #1 chosen from 1 choice
Apr 12 11:49:26 localhost kernel: usbcore: registered new driver hiddev
Apr 12 11:49:26 localhost kernel: hdb: IDE DVD-ROM 16X, ATAPI CD/DVD-ROM drive
Apr 12 11:49:26 localhost kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Apr 12 11:49:26 localhost kernel: input: Logitech Optical USB Mouse as /class/input/input1
Apr 12 11:49:26 localhost kernel: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:03.1-1
Apr 12 11:49:26 localhost kernel: usbcore: registered new driver usbhid
Apr 12 11:49:26 localhost kernel: drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Apr 12 11:49:26 localhost kernel: hdc: ST340016A, ATA DISK drive
Apr 12 11:49:26 localhost kernel: hdd: LITE-ON LTR-40125S, ATAPI CD/DVD-ROM drive
Apr 12 11:49:26 localhost kernel: ide1 at 0x170-0x177,0x376 on irq 15
Apr 12 11:49:26 localhost kernel: ACPI: PCI Interrupt 0000:00:0e.0[A] -> GSI 16 (level, low) -> IRQ 217
Apr 12 11:49:26 localhost kernel: ata1: SATA max UDMA/133 cmd 0xD0940200 ctl 0xD0940238 bmdma 0x0 irq 217
Apr 12 11:49:26 localhost kernel: ata2: SATA max UDMA/133 cmd 0xD0940280 ctl 0xD09402B8 bmdma 0x0 irq 217
Apr 12 11:49:26 localhost kernel: hdc: max request size: 128KiB
Apr 12 11:49:26 localhost kernel: hdc: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
Apr 12 11:49:26 localhost kernel: hdc: cache flushes not supported
Apr 12 11:49:26 localhost kernel: hdc:<6>hdb: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Apr 12 11:49:26 localhost kernel: Uniform CD-ROM driver Revision: 3.20
Apr 12 11:49:26 localhost kernel: ata1: SATA link down (SStatus 0)
Apr 12 11:49:26 localhost kernel: scsi0 : sata_promise
Apr 12 11:49:26 localhost kernel: ata2: SATA link down (SStatus 0)
Apr 12 11:49:26 localhost kernel: scsi1 : sata_promise
Apr 12 11:49:26 localhost kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Apr 12 11:49:26 localhost kernel: hdc: dma_intr: error=0x84 { DriveStatusError BadCRC }
Apr 12 11:49:26 localhost kernel: ide: failed opcode was: unknown
Apr 12 11:49:26 localhost kernel: hdd: DMA disabled
Apr 12 11:49:26 localhost kernel: ide1: reset: success
Apr 12 11:49:26 localhost kernel: hdc1 hdc2 hdc3 hdc4 < hdc5 hdc6 >
Apr 12 11:49:26 localhost kernel: hdd: ATAPI 48X CD-ROM CD-R/RW drive, 2048kB Cache
Apr 12 11:49:27 localhost kernel: ide: failed opcode was: unknown
Apr 12 11:49:27 localhost kernel: hdc: dma_intr: status=0x51 { DriveReady SeekComplete Error }
Apr 12 11:49:27 localhost kernel: hdc: dma_intr: error=0x84 { DriveStatusError BadCRC }
Apr 12 11:49:27 localhost kernel: ide1: reset: success
Apr 12 11:49:27 localhost kernel: Attempting manual resume
Apr 12 11:49:27 localhost kernel: EXT3-fs: INFO: recovery required on readonly filesystem.
Apr 12 11:49:27 localhost kernel: EXT3-fs: write access will be enabled during recovery.
Apr 12 11:49:27 localhost kernel: kjournald starting. Commit interval 5 seconds
Apr 12 11:49:27 localhost kernel: EXT3-fs: recovery complete.
Apr 12 11:49:27 localhost kernel: EXT3-fs: mounted filesystem with ordered data mode.
Apr 12 11:49:27 localhost kernel: i2c-sis96x version 1.0.0
Apr 12 11:49:27 localhost kernel: sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0xe600
Apr 12 11:49:27 localhost kernel: gameport: EMU10K1 is pci0000:00:0b.1/gameport0, io 0x9000, speed 806kHz
Apr 12 11:49:27 localhost kernel: Real Time Clock Driver v1.12ac
Apr 12 11:49:27 localhost kernel: gameport: NS558 PnP Gameport is pnp00:0e/gameport0, io 0x200, speed 648kHz
Apr 12 11:49:27 localhost kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Apr 12 11:49:27 localhost kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Apr 12 11:49:27 localhost kernel: Linux agpgart interface v0.101 (c) Dave Jones
Apr 12 11:49:27 localhost kernel: parport: PnPBIOS parport detected.
Apr 12 11:49:27 localhost kernel: parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
Apr 12 11:49:27 localhost kernel: agpgart: Detected SiS 648 chipset
Apr 12 11:49:27 localhost kernel: agpgart: AGP aperture is 64M @ 0xd8000000
Apr 12 11:49:27 localhost kernel: Floppy drive(s): fd0 is 1.44M
Apr 12 11:49:27 localhost kernel: FDC 0 is a post-1991 82077
Apr 12 11:49:27 localhost kernel: eth1394: eth1: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
Apr 12 11:49:27 localhost kernel: input: PC Speaker as /class/input/input2
Apr 12 11:49:27 localhost kernel: ACPI: PCI Interrupt 0000:00:0b.0[A] -> GSI 19 (level, low) -> IRQ 177
Apr 12 11:49:27 localhost kernel: ts: Compaq touchscreen protocol output
Apr 12 11:49:27 localhost kernel: mice: PS/2 mouse device common for all mice
Apr 12 11:49:27 localhost kernel: Adding 976744k swap on /dev/hdc3. Priority:-1 extents:1 across:976744k
Apr 12 11:49:27 localhost kernel: EXT3 FS on hdc5, internal journal
Apr 12 11:49:27 localhost kernel: apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
Apr 12 11:49:27 localhost kernel: apm: overridden by ACPI.
Apr 12 11:49:27 localhost kernel: device-mapper: 4.5.0-ioctl (2005-10-04) initialised: dm-devel@redhat.com
Apr 12 11:49:27 localhost kernel: EXT3 FS on hdc2, internal journal
Apr 12 11:49:27 localhost kernel: eth0: Media Link On 100mbps full-duplex
Apr 12 11:49:27 localhost kernel: lp0: using parport0 (interrupt-driven).
Apr 12 11:49:31 localhost lpd[6267]: restarted
Apr 12 11:49:32 localhost kernel: NET: Registered protocol family 10
Apr 12 11:49:32 localhost kernel: lo: Disabled Privacy Extensions
Apr 12 11:49:32 localhost kernel: IPv6 over IPv4 tunneling driver
Apr 12 11:49:34 localhost kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Apr 12 11:49:34 localhost kernel: Netfilter messages via NETLINK v0.30.
Apr 12 11:49:34 localhost kernel: ip_conntrack version 2.4 (4095 buckets, 32760 max) - 232 bytes per conntrack
Apr 12 11:54:14 localhost shutdown[6526]: shutting down for system halt
Apr 12 11:54:20 localhost kernel: Kernel logging (proc) stopped.
Apr 12 11:54:20 localhost kernel: Kernel log daemon terminating.
Apr 12 11:54:21 localhost exiting on signal 15
Ricardo: c’est un log de boot, il n’y a rien à en tirer quant au fonctionnement de X
Qu’est-ce que je dois faire alors ?
Donnes plutot ton Xorg.0.log (je ne sais plus s’il s’appelle comme ça, mais tu dois pouvoir retrouver le bon log dans /var/log
PS: quelqu’un vient d’ouvrir un autre fil avec le même problême. Je vais le rediriger ici, mais as tu reregardé récemment si le problême n’était pas traité depuis que tu as fait ton update ?
C’est le genre de bug que les equipes debian ne trainent pas à corriger, me semble t il…
Et si c’est pas corrigé verifie que les repertoires des fontes (FontPath…) pointent bien vers des repertoires existants. J’ai eu le problème quand j’ai testé Xorg en experimental.
Il y a un script interessant qui existe:
kanotix.com/files/fix-xorg7.sh
Salut Matt, j’étais absent hier soir mais voilà le log demandé et il semblerait que c’est une histoire de NVIDIA.
Comme j’avais eu des problèmes à l’install du nveau driver NVIdia, il avait fallu installer un patch.
Serait-il possible qu’après un dist-upgrade ce patch ait disparu ?
À ton avis, est ce que je dois réinstaller complètement NVUDIA + ce fameux patch ?
Je vois en effet que je ne suis pas seul à avoir ce problème.
[code]X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.12-1-686 i686
Current Operating System: Linux ricardo 2.6.16-1-686 #2 Mon Apr 10 22:16:40 UTC 2006 i686
Build Date: 16 March 2006
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Wed Apr 12 16:36:21 2006
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “Default Screen” (0)
() | |–>Monitor “Écran générique”
() | |–>Device “Carte vidéo générique”
() |–>Input Device “Generic Keyboard”
() Option “XkbRules” “xorg”
() XKB: rules: “xorg”
() Option “XkbModel” “pc105”
() XKB: model: “pc105”
() Option “XkbLayout” “fr”
() XKB: layout: “fr”
(==) Keyboard: CustomKeycode disabled
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/lib/X11/fonts/cyrillic” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/lib/X11/fonts/CID” does not exist.
(**) FontPath set to “unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi”
(==) RgbPath set to “/usr/share/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.8
(–) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1039,0648 card 1043,8086 rev 02 class 06,00,00 hdr 80
(II) PCI: 00:01:0: chip 1039,0001 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 1039,0963 card 0000,0000 rev 04 class 06,01,00 hdr 80
(II) PCI: 00:02:1: chip 1039,0016 card 0000,0000 rev 00 class 0c,05,00 hdr 00
(II) PCI: 00:02:3: chip 1039,7007 card 0000,00ff rev 00 class 0c,00,10 hdr 00
(II) PCI: 00:02:5: chip 1039,5513 card 1043,8087 rev 00 class 01,01,80 hdr 00
(II) PCI: 00:03:0: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 80
(II) PCI: 00:03:1: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:2: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:3: chip 1039,7002 card 1043,8087 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:04:0: chip 1039,0900 card 1043,80a7 rev 91 class 02,00,00 hdr 00
(II) PCI: 00:0b:0: chip 1102,0002 card 1102,8066 rev 0a class 04,01,00 hdr 80
(II) PCI: 00:0b:1: chip 1102,7002 card 1102,0020 rev 0a class 09,80,00 hdr 80
(II) PCI: 00:0e:0: chip 105a,3376 card 1043,809e rev 02 class 01,04,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0221 card 1554,11b1 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd6000000 - 0xd7ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xdff00000 - 0xfebfffff (0x1ed00000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:2:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) nVidia Corporation GeForce 6200 rev 161, Mem @ 0xd7000000/24, 0xe0000000/28, 0xd6000000/24, BIOS @ 0xdffe0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd8000000 from 0xdbffffff to 0xd7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xd2000000 - 0xd201ffff (0x20000) MX[B]
[1] -1 0 0xd2800000 - 0xd2800fff (0x1000) MX[B]
[2] -1 0 0xd3000000 - 0xd3000fff (0x1000) MX[B]
[3] -1 0 0xd3800000 - 0xd3800fff (0x1000) MX[B]
[4] -1 0 0xd4000000 - 0xd4000fff (0x1000) MX[B]
[5] -1 0 0xd4800000 - 0xd4800fff (0x1000) MX[B]
[6] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[7] -1 0 0xd5800000 - 0xd5800fff (0x1000) MX[B]
[8] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]O
[9] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MXB
[10] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MXB
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[12] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MXB
[13] -1 0 0x00008000 - 0x0000807f (0x80) IX[B]
[14] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[15] -1 0 0x00008800 - 0x0000883f (0x40) IX[B]
[16] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[17] -1 0 0x00009400 - 0x0000941f (0x20) IX[B]
[18] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[19] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
[20] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xd2000000 - 0xd201ffff (0x20000) MX[B]
[6] -1 0 0xd2800000 - 0xd2800fff (0x1000) MX[B]
[7] -1 0 0xd3000000 - 0xd3000fff (0x1000) MX[B]
[8] -1 0 0xd3800000 - 0xd3800fff (0x1000) MX[B]
[9] -1 0 0xd4000000 - 0xd4000fff (0x1000) MX[B]
[10] -1 0 0xd4800000 - 0xd4800fff (0x1000) MX[B]
[11] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[12] -1 0 0xd5800000 - 0xd5800fff (0x1000) MX[B]
[13] -1 0 0xd8000000 - 0xd7ffffff (0x0) MX[B]O
[14] -1 0 0xdffe0000 - 0xdfffffff (0x20000) MXB
[15] -1 0 0xd6000000 - 0xd6ffffff (0x1000000) MXB
[16] -1 0 0xe0000000 - 0xefffffff (0x10000000) MXB
[17] -1 0 0xd7000000 - 0xd7ffffff (0x1000000) MXB
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x00008000 - 0x0000807f (0x80) IX[B]
[21] -1 0 0x00008400 - 0x0000840f (0x10) IX[B]
[22] -1 0 0x00008800 - 0x0000883f (0x40) IX[B]
[23] -1 0 0x00009000 - 0x00009007 (0x8) IX[B]
[24] -1 0 0x00009400 - 0x0000941f (0x20) IX[B]
[25] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[26] -1 0 0x0000b400 - 0x0000b40f (0x10) IX[B]
[27] -1 0 0x0000e600 - 0x0000e61f (0x20) IX[B]
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.0.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(II) Loading sub module “GLcore”
(II) LoadModule: “GLcore”
(II) Loading /usr/lib/xorg/modules/extensions/libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “type1”
(II) Loading /usr/lib/xorg/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.1.0
(II) LoadModule: “nvidia”
(WW) Warning, couldn’t open module nvidia
(II) UnloadModule: “nvidia”
(EE) Failed to load module “nvidia” (module does not exist, 0)
(II) LoadModule: “keyboard”
(II) Loading /usr/lib/xorg/modules/input/keyboard_drv.so
(II) Module keyboard: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.0.0, module version = 1.0.4
(EE) No drivers available.
Fatal server error:
no screens found
PS :
je suppose qu’on va me demander un lsmod mais je ne sais pas comment lire en page par page en mode texte alors 'lsmod me donne juste la fin.
J’ai essayé en chrootant mais il me dit que /proc est vide ???
lire page à page ca doit être
lsmod | pager
sur l’indication, je me redirige ici (merci Ricardo d’avoir ouvert ce fil), car j’ai le (même?) problème :
xauth: creating new authority file /home/kataman/.serverauth.3301
X: /etc/X11/X points back to X wrapper executable, aborting.
giving up.
/usr/X11R6/bin/xinit: Connection refused (errno 111): unable to connect to X server
/usr/X11R6/bin/xinit: No such process (errno 3): Server error.
j’essaie de copier mon XFree86.0.log (dur de monter la disquette!!) :
bon, j’essaierai + tard :
le X pour répondre à BorisTheButcher :
“type X” me donne : "X is hashed (usr/bin/X11/X)"
ds /usr/bin/X11, X pointe sur …/X11R6/bin
et /etc/X11/X pointe aussi sur /usr/X11R6/bin/X
ds /usr/X11R6/bin, X est un ?? :
-rwsr-sr-x 1 root root 9704 2006-04-05 03:18 /usr/X11R6/bin/X
un AUTO-POINTEUR ?? Comment ai-je fait ça??
pour MattOTop :
je ne crois pas que je sois en Xorg, d’après ce que je viens d’écrire ?? (et je n’ai rien dans /var/log à ce sujet, mais il est peut-être installé quand même)
je confirme,
lsmod | pager fonctionne, tout comme lsmod | more
par contre je n’arrive pas à savoir si j’ai un XFree ou un Xorg!!
dpkg -l | wc -l --> 893
mais dpkg -l X (ou X) ne donne rien ??
[code]dpkg -l | grep xfree[/code]
Si ca ne te renvoi rien c'est que ce n'est pas installé sinon il te dira quel paquet est installé :slightly_smiling:
Si ca ne te renvoi rien c’est que ce n’est pas installé sinon il te dira quel paquet est installé
Alors, j’ai vérifié et nvidia est bien présent ds lsmod.
J’ai fait l’essai en supprimant GLX mais sans + de rslt.
J’ai tenté de recharger complètement le driver NVIDIA et le patch qui va avec, selon le conseil du site NVIDIA = pas mieux, tjrs m^ réponse : pas de module nvidia.
j’abandonne et je vais me suicider chez Windaube
la fin du log :
code LoadModule: “nvidia”
Fatal server error:
no screens found
J’ai aussi un module ‘nvidia.ko’ ds /lib/modules/…/video
Ricardo: pas d’idée pour l’instant.
Thomas: pour savoir si un paquet est installé ou pas, 'aptitude seacch ’ te donne le statut d’installation des différents paquets, par exemple:
console@routeur:~$ aptitude search xserver-xfree
p xserver-xfree86 - transitional package for moving from xfree86 to X.Org
p xserver-xfree86-dbg - the XFree86 X server (static version with debugging symbols)
Bon, là, les deux paquets sont §urgés, c’est à dire pas installés et sans reste de config, mais ils peuvent être (i)nstallés, etc…
Je ne l’ai pas fait avec xserver-xorg, parceque c’est un peu long.
[quote=“ricardo”]
et si tu installais tout simplement les paquets prévus à cet effet et disponibles via aptitude / synaptic avant de tenter de te suicider?
compiler soi-meme c’est bien beau mais 'faut assumer aussi après …
Merci pour ces infos, j’utilisais mal grep
rc xfree86-common 6.9.0.dfsg.1-4 X Window System infrastructure transitional
rc xserver-xfree86 4.3.0.dfsg.1-14sarge1 the XFree86 X server
ii libglu1-xorg 6.9.0.dfsg.1-4 Mesa OpenGL utility library [X.Org]
ii xserver-xorg 6.9.0.dfsg.1-6 the X.Org X server
voilà donc les résultats pour dpkg. Par contre je ne comprends pas leur état
j’imagine qu’ii est qqpart du côté d’installé, mais rc ??
cherche explication désespérement (la page man de dpkg ne donne pas d’exemples de résultats, ni un copier/coller ds Google)
et le même côté aptitude :
i A libglu1-xorg - Mesa OpenGL utility library [X.Org]
p libglu1-xorg-dbg - Mesa OpenGL utility library (unstripped) [
p libglu1-xorg-dev - Mesa OpenGL utility library development fi
i A xserver-xorg - the X.Org X server
p xserver-xorg-dbg - debugging symbols for the X.Org X server
c xfree86-common - X Window System infrastructure transitiona
p xfree86-driver-synaptics - Synaptics TouchPad driver for X.Org/XFree8
p xfreecd - a GTK-based CD Player
c xserver-xfree86 - transitional package for moving from xfree
donc j’y vois un peu plus clair … enfin, je crois … ‘c’, c’est pour configuré?
Enfin, ne m’en veuillez pas svp, merci pour votre aide et votre gentillesse, mais je manque de ténacité, et je vais aller me “suicider” chez Mandriva … en espérant que ce soit stable (en dernier recours, j’ai honte, mais on vient de me donner une licence “… Pro” sous cellophane
Je devrais avoir rapidement l’occasion de perséverer et revenir à Debian (dès que l’architecture Xen/Pacifica sera opérationnelle et bon marché
Au revoir
[quote]et si tu installais tout simplement les paquets prévus à cet effet et disponibles via aptitude / synaptic avant de tenter de te suicider?
_________________[/quote]
Je ne comprends pas ce que tu me reproches Ghostin, je n’ai rien fait que de très normal, il me semble :
mettre à jour en upgradant (update puis dist-upgrade)
ensuite, j’ai configuré le noyau sans le changer en profondeur mais seulement en l’affinant selon mon matos.
J’ai m^ rechargé une image 2.6.15 et cette fois avec l’ancien pilote NVIDIA mais le rslt est tjrs négatif, m^ log que celui montré au dessus.
J’ajoute que sur ma Debian fonctionnelle, tt baigne parfaitement et pourtant, elle aussi, je l’ai recompilée.
Je continue de chercher.
Malgré encore pas mal d’expériences de ts ordres hier soir, j’arrive tjrs au m^ problème.
J’ai rechargé une image 2.6.15-1-686 et j’ai installé un ancien driver NVIDIA qui fonctionne bien sur mes Debian fonctionnelles : le driver s’installe bien mais à l’arrivée, inconnu ?
Je vais essayer de “faire le ménage” car j’ai l’impression qu’il y a des conflits qq part.
Ma question :
Quels sont les fichiers à éliminer pour faire le vide et où les trouver. Peut-on les virer directement ou doit-on désinstaller et comment ?
J’ai quand m^ réussi à rentrer sous x une 2.6.16-ricardo
Il ne m’aura fallu que 4 ou 5 heures et tout essayer les différents tutos ds le trucs et astuces de Ghostin.
Quel galère quand m^ avec ce NVIDIA
