Un collègue à vous m’avait installé un driver GSPCA via le site boisson.homeip.net/gspcav1-20061216.tar.gz
il y a 3 mois environ et tout fonctionnait parfaitement.
Maintenant : deb:/lib/modules/2.6.18-3-686/misc# depmod -ae
deb:/lib/modules/2.6.18-3-686/misc# modprobe gspca
FATAL: Error inserting gspca (/lib/modules/2.6.18-3-686/misc/gspca.ko): Unknown symbol in module, or unknown parameter (see dmesg)
deb:/lib/modules/2.6.18-3-686/misc# dmesg
Linux version 2.6.18-3-686 (Debian 2.6.18-7) (waldi@debian.org) (gcc version 4.1 .2 20061115 (prerelease) (Debian 4.1.1-20)) #1 SMP Mon Dec 4 16:41:14 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e6000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000002dfb0000 (usable)
BIOS-e820: 000000002dfb0000 - 000000002dfc0000 (ACPI data)
BIOS-e820: 000000002dfc0000 - 000000002dff0000 (ACPI NVS)
BIOS-e820: 000000002dff0000 - 000000002e000000 (reserved)
BIOS-e820: 00000000ff780000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
735MB LOWMEM available.
found SMP MP-table at 000ff780
On node 0 totalpages: 188336
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 184240 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 ACPIAM ) @ 0x000fac80
ACPI: RSDT (v001 A M I OEMRSDT 0x06000524 MSFT 0x00000097) @ 0x2dfb0000
ACPI: FADT (v002 A M I OEMFACP 0x06000524 MSFT 0x00000097) @ 0x2dfb0200
ACPI: MADT (v001 A M I OEMAPIC 0x06000524 MSFT 0x00000097) @ 0x2dfb0390
ACPI: OEMB (v001 A M I AMI_OEM 0x06000524 MSFT 0x00000097) @ 0x2dfc0040
ACPI: DSDT (v001 P4V80 P4V80000 0x00000000 INTL 0x02002026) @ 0x00000000
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:4 APIC version 20
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 2e000000:d1780000)
Detected 2533.507 MHz processor.
Built 1 zonelists. Total pages: 188336
Kernel command line: root=/dev/hda1 ro
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 739000k/753344k available (1543k kernel code, 13768k reserved, 574k data , 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 5073.80 BogoMIPS (lpj=10147618)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: bfebfbff 00000000 00000000 00000000 0000441d 00000000 00000000
CPU: After vendor identify, caps: bfebfbff 00000000 00000000 00000000 0000441d 0 0000000 00000000
monitor/mwait feature present.
using mwait in idle threads.
CPU: Trace cache: 12K uops, L1 D cache: 16K
CPU: L2 cache: 256K
CPU: Hyper-Threading is disabled
CPU: After all inits, caps: bfebfbff 00000000 00000000 00000180 0000441d 0000000 0 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
CPU0: Thermal monitoring enabled
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
CPU0: Intel® Celeron® CPU 2.53GHz stepping 01
Total of 1 processors activated (5073.80 BogoMIPS).
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs… it is
Freeing initrd memory: 4404k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.P0P1._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 12 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: fca00000-feafffff
PREFETCH window: eff00000-f7efffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1171808209.888:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: Bypassing VIA 8237 APIC De-Assert Message
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0f03:PS2M] at 0x60,0x64 irq 12
PNP: PS/2 controller doesn’t have KBD irq; using default 1
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S3<6>Time: tsc clocksource has been installed.
S4 S5)
Freeing unused kernel memory: 196k freed
ACPI Exception (acpi_processor-0681): AE_NOT_FOUND, Processor Device is not pres ent [20060707]
ACPI: Getting cpuindex for acpiid 0x2
SCSI subsystem initialized
libata version 2.00 loaded.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
ACPI: PCI Interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 169
PCI: VIA IRQ fixup for 0000:00:0f.1, from 255 to 9
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0…
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
via-rhine.c:v1.10-LK1.4.1 July-24-2006 Written by Donald Becker
hda: HDS728080PLAT20, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
hdc: TSSTcorpCD/DVDW SH-W162C, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
sata_via 0000:00:0f.0: version 2.0
ACPI: PCI Interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 169
sata_via 0000:00:0f.0: routed to hard irq line 11
ata1: SATA max UDMA/133 cmd 0xEC00 ctl 0xE802 bmdma 0xDC00 irq 169
ata2: SATA max UDMA/133 cmd 0xE400 ctl 0xE002 bmdma 0xDC08 irq 169
scsi0 : sata_via
hda: max request size: 512KiB
hda: 160836480 sectors (82348 MB) w/1719KiB Cache, CHS=16383/255/63, UDMA(133)
hda: cache flushes supported
hda: hda1 hda2 < hda5 >
hdc: ATAPI 94X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ata1: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xEC07
scsi1 : sata_via
ata2: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xE407
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.0, from 10 to 1
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 177, io base 0x0000c000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.1, from 10 to 1
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 177, io base 0x0000c400
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.2, from 11 to 1
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 177, io base 0x0000c800
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 177
PCI: VIA IRQ fixup for 0000:00:10.3, from 11 to 1
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
uhci_hcd 0000:00:10.3: irq 177, io base 0x0000cc00
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
usb 1-1: new full speed USB device using uhci_hcd and address 2
ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 23 (level, low) -> IRQ 185
eth0: VIA Rhine II at 0x1d400, 00:13:8f:22:a0:aa, IRQ 185.
eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 45e1.
usb 1-1: configuration #1 chosen from 1 choice
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
usb 2-2: new low speed USB device using uhci_hcd and address 2
usb 2-2: configuration #1 chosen from 1 choice
usb 3-1: new full speed USB device using uhci_hcd and address 2
usb 3-1: configuration #1 chosen from 1 choice
Linux agpgart interface v0.101 © Dave Jones
agpgart: Detected VIA P4M800CE chipset
agpgart: AGP aperture is 64M @ 0xf8000000
Real Time Clock Driver v1.12ac
Linux video capture interface: v2.00
input: PC Speaker as /class/input/input0
gspca: disagrees about version of symbol video_devdata
gspca: Unknown symbol video_devdata
gspca: disagrees about version of symbol video_unregister_device
gspca: Unknown symbol video_unregister_device
gspca: disagrees about version of symbol video_device_alloc
gspca: Unknown symbol video_device_alloc
gspca: disagrees about version of symbol video_register_device
gspca: Unknown symbol video_register_device
gspca: disagrees about version of symbol video_device_release
gspca: Unknown symbol video_device_release
usbcore: registered new driver hiddev
input: USB Keyboard as /class/input/input1
input: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:10.1-2
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP ,DMA]
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
FDC 0 is a post-1991 82077
input: USB Keyboard as /class/input/input2
input: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:10.1-2
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Initializing USB Mass Storage driver…
scsi2 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
saa7130/34: v4l2 driver version 0.2.14 loaded
ACPI: PCI Interrupt 0000:00:09.0[A] -> GSI 17 (level, low) -> IRQ 193
saa7133[0]: found at 0000:00:09.0, rev: 208, irq: 193, latency: 32, mmio: 0xfebf f000
saa7133[0]: subsystem: 1043:4862, board: ASUSTeK P7131 Dual [card=78,autodetecte d]
saa7133[0]: board init: gpio is 0
saa7133[0]: gpio: mode=0x0000000 in=0x0000000 out=0x0000000 [pre-init]
input: saa7134 IR (ASUSTeK P7131 Dual) as /class/input/input3
saa7133[0]: i2c eeprom 00: 43 10 62 48 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
saa7133[0]: i2c eeprom 10: 00 01 20 00 ff 20 ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 20: 01 40 01 02 03 01 01 03 08 ff 00 d6 ff ff ff ff
saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 40: ff 21 00 c2 96 10 03 32 15 00 ff ff ff ff ff ff
saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: gpio: mode=0x0200000 in=0x0000000 out=0x0000000 [Television]
tuner 1-004b: chip found @ 0x96 (saa7133[0])
tuner 1-004b: setting tuner address to 61
tuner 1-004b: type set to tda8290+75a
input: ImPS/2 Generic Wheel Mouse as /class/input/input4
saa7133[0]: registered device video0 [v4l2]
saa7133[0]: registered device vbi0
saa7133[0]: registered device radio0
ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:11.5 to 64
ts: Compaq touchscreen protocol output
Adding 650592k swap on /dev/hda5. Priority:-1 extents:1 across:650592k
EXT3 FS on hda1, internal journal
DVB: registering new adapter (saa7133[0]).
DVB: registering frontend 0 (Philips TDA10046H DVB-T)…
quickcam: disagrees about version of symbol video_devdata
quickcam: Unknown symbol video_devdata
quickcam: disagrees about version of symbol video_unregister_device
quickcam: Unknown symbol video_unregister_device
quickcam: disagrees about version of symbol video_register_device
quickcam: Unknown symbol video_register_device
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Vendor: Generic Model: 2.0 Reader-CF Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 00
Vendor: Generic Model: 2.0 Reader-SM/xD Rev: 1.00
Vendor: Generic Model: 2.0 Reader-SD Rev: 1.00
Vendor: Generic Model: 2.0 Reader-MS Rev: 1.00
sd 2:0:0:0: Attached scsi removable disk sda
sd 2:0:0:1: Attached scsi removable disk sdb
sd 2:0:0:2: Attached scsi removable disk sdc
usb-storage: device scan complete
sd 2:0:0:3: Attached scsi removable disk sdd
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
apm: BIOS version 1.2 Flags 0x02 (Driver version 1.16ac)
apm: overridden by ACPI.
eth0: no IPv6 routers present
ISO 9660 Extensions: Microsoft Joliet Level 3
ISOFS: changing to secondary root
J’espère que cette log suffira pour identifier le problème.
A votre disposition pour faire avancer ce post.
