Bonsoir a tous,
depuis peu mon scanner lexmark X1150 n’est plus reconnu par xsane.
Cependant sane-find-scanner lui le trouve bien
[code]sane-find-scanner
sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x043d, product=0x007c, chip=rts8858c) at libusb:004:014
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
du coup comme demandé j’essais le scanimage -L
[code]scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
ici un extrait du kernel.log lors du branchement du scanner :
May 12 20:18:50 portable kernel: [ 487.728073] usb 4-1: new full speed USB device using uhci_hcd and address 13
May 12 20:18:51 portable kernel: [ 487.900964] usb 4-1: New USB device found, idVendor=043d, idProduct=007a
May 12 20:18:51 portable kernel: [ 487.900973] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 12 20:18:51 portable kernel: [ 487.900980] usb 4-1: Product: USB Hub
May 12 20:18:51 portable kernel: [ 487.900985] usb 4-1: Manufacturer: Lexmark
May 12 20:18:51 portable kernel: [ 487.901166] usb 4-1: configuration #1 chosen from 1 choice
May 12 20:18:51 portable kernel: [ 487.904395] hub 4-1:1.0: USB hub found
May 12 20:18:51 portable kernel: [ 487.905965] hub 4-1:1.0: 2 ports detected
May 12 20:18:51 portable kernel: [ 488.185977] usb 4-1.1: new full speed USB device using uhci_hcd and address 14
May 12 20:18:51 portable kernel: [ 488.329981] usb 4-1.1: New USB device found, idVendor=043d, idProduct=007c
May 12 20:18:51 portable kernel: [ 488.329990] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=7
May 12 20:18:51 portable kernel: [ 488.329997] usb 4-1.1: Product: X1100 Series
May 12 20:18:51 portable kernel: [ 488.330002] usb 4-1.1: Manufacturer: Lexmark
May 12 20:18:51 portable kernel: [ 488.330007] usb 4-1.1: SerialNumber: 6809949
May 12 20:18:51 portable kernel: [ 488.330202] usb 4-1.1: configuration #1 chosen from 1 choice
May 12 20:18:51 portable kernel: [ 488.413980] usb 4-1.2: new full speed USB device using uhci_hcd and address 15
May 12 20:18:51 portable kernel: [ 488.554982] usb 4-1.2: New USB device found, idVendor=043d, idProduct=007b
May 12 20:18:51 portable kernel: [ 488.554991] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 12 20:18:51 portable kernel: [ 488.554998] usb 4-1.2: Product: Lexmark X1100 Series
May 12 20:18:51 portable kernel: [ 488.555004] usb 4-1.2: Manufacturer: Lexmark
May 12 20:18:51 portable kernel: [ 488.555009] usb 4-1.2: SerialNumber: 6809949
May 12 20:18:51 portable kernel: [ 488.555209] usb 4-1.2: configuration #1 chosen from 1 choice
May 12 20:18:51 portable kernel: [ 488.562861] usblp0: USB Bidirectional printer dev 15 if 0 alt 0 proto 2 vid 0x043D pid 0x007B
Pour moi rien d’anormal …
Systeme en SID avec xfce et xsane ( et ce qui est lié) de stable (xfce 4.8 a trop de bug graphique donc downgrade et comme xsane ne trouvait pas mon scanner je l’ai downgradé dans la foulé)
kernel : Linux portable 2.6.32-5-686 #1 SMP Fri Dec 10 16:12:40 UTC 2010 i686 GNU/Linux
