Salut à tous !
Je sépare les commandes en plusieurs morceaux, afin d’essayer de rendre ça plus lisible.
$ dmesg | grep -i -A 2 -B 2 -C 2 ata
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cff90000 (usable)
[ 0.000000] BIOS-e820: 00000000cff90000 - 00000000cffa8000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cffa8000 - 00000000cffd0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cffd0000 - 00000000d0000000 (reserved)
[ 0.000000] Entering add_active_range(0, 1048576, 1179648) 2 entries of 3200 used
[ 0.000000] Bootmem setup node 0 0000000000000000-0000000120000000
[ 0.000000] NODE_DATA [000000000000e000 - 0000000000012fff]
[ 0.000000] bootmap [0000000000013000 - 0000000000036fff] pages 24
[ 0.000000] early res: 0 [0-fff] BIOS data page
[ 0.000000] early res: 1 [6000-7fff] TRAMPOLINE
[ 0.000000] early res: 2 [200000-675397] TEXT DATA BSS
[ 0.000000] early res: 3 [7f3a4000-7ffff27d] RAMDISK
[ 0.000000] early res: 4 [9ec00-fffff] BIOS reserved
[ 0.000000] Allocating PCI resources starting at d4000000 (gap: d0000000:2f700000)
[ 0.000000] SMP: Allowing 6 CPUs, 4 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37168 bytes of per cpu data
[ 0.000000] NR_CPUS: 32, nr_cpu_ids: 6
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 965453
[ 0.004000] Mapping aperture over 65536 KB of RAM @ 4000000
[ 0.004000] PM: Registered nosave memory: 0000000004000000 - 0000000008000000
[ 0.004000] Memory: 3792752k/4718592k available (2228k kernel code, 138568k reserved, 1081k data, 392k init)
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.004000] hpet clockevent registered
[ 0.291817] PCI: Using MMCONFIG at e0000000 - efffffff
[ 0.304399] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.304399] pci 0000:00:11.0: set SATA to AHCI mode
[ 0.304399] PCI: Transparent bridge - 0000:00:14.4
[ 0.304399] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 1.477387] Uniform Multi-Platform E-IDE driver
[ 1.477391] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 1.477596] libata version 3.00 loaded.
[ 1.520527] pnp: the driver 'parport_pc' has been registered
[ 1.520541] parport_pc 00:08: reported by Plug and Play ACPI
[ 2.625975] usb 4-3: Manufacturer: Logitech
[ 2.853634] ieee1394: Host added: ID:BUS[0-00:1023] GUID[001e8c0000c47f8e]
[ 3.316786] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 3.316789] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[ 3.318286] scsi0 : ahci
[ 3.318293] scsi2 : ahci
[ 3.318608] scsi3 : ahci
[ 3.318608] ata1: SATA max UDMA/133 abar m1024@0xfe7ffc00 port 0xfe7ffd00 irq 22
[ 3.318608] ata2: SATA max UDMA/133 abar m1024@0xfe7ffc00 port 0xfe7ffd80 irq 22
[ 3.318608] ata3: SATA max UDMA/133 abar m1024@0xfe7ffc00 port 0xfe7ffe00 irq 22
[ 3.318608] ata4: SATA max UDMA/133 abar m1024@0xfe7ffc00 port 0xfe7ffe80 irq 22
[ 3.740598] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.076598] ata2: SATA link down (SStatus 0 SControl 300)
[ 4.708545] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.712507] ata3.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ 4.712507] ata3: failed to recover some devices, retrying in 5 secs
[ 11.384165] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 11.384379] ata3.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ 11.384382] ata3: failed to recover some devices, retrying in 5 secs
[ 17.947620] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 17.947833] ata3.00: failed to IDENTIFY (INIT_DEV_PARAMS failed, err_mask=0x80)
[ 17.947836] ata3: failed to recover some devices, retrying in 5 secs
[ 24.224181] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 24.668172] ata4: SATA link down (SStatus 0 SControl 300)
[ 24.688144] ACPI: PCI Interrupt 0000:00:12.2[B] -> GSI 17 (level, low) -> IRQ 17
[ 24.688144] ehci_hcd 0000:00:12.2: EHCI Host Controller
[ 25.719571] usb 4-3: Manufacturer: Logitech
[ 25.815922] Probing IDE interface ide1...
[ 26.139403] hdc: WDC WD15EARS-00Z5B1, ATA DISK drive
[ 27.043312] hdd: TSSTcorp CDDVDW SH-S223C, ATAPI CD/DVD-ROM drive
[ 27.099086] hdc: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 27.099158] hdc: UDMA/100 mode selected
[ 27.103360] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 27.103360] ide1 at 0x170-0x177,0x376 on irq 15
[ 27.777313] hdd: ATAPI 40X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
[ 27.777318] Uniform CD-ROM driver Revision: 3.20
[ 27.786575] hdc: max request size: 512KiB
[120575.800585] EXT3-fs warning: mounting unchecked fs, running e2fsck is recommended
[120575.887150] EXT3 FS on dm-0, internal journal
[120575.887150] EXT3-fs: mounted filesystem with ordered data mode.
[120575.964439] kjournald starting. Commit interval 5 seconds
[120575.966207] EXT3 FS on dm-4, internal journal
[120575.966212] EXT3-fs: mounted filesystem with ordered data mode.
[120576.017769] kjournald starting. Commit interval 5 seconds
[120576.020668] EXT3 FS on dm-2, internal journal
[120576.020673] EXT3-fs: mounted filesystem with ordered data mode.
[120576.056767] kjournald starting. Commit interval 5 seconds
[120576.057974] EXT3 FS on dm-3, internal journal
[120576.057979] EXT3-fs: mounted filesystem with ordered data mode.
$ dmesg | grep -i -A 2 -B 2 -C 2 ide
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 2.6.26-2-amd64 (Debian 2.6.26-21) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25)) #1 SMP Tue Jan 12 22:12:20 UTC 2010
[ 0.000000] Command line: video=vesa:ywrap,mtrr vga=788 initrd=/install.amd/gtk/initrd.gz rescue/enable=true -- quiet BOOT_IMAGE=/install.amd/vmlinuz
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Setting APIC routing to flat
[ 0.000000] ACPI: HPET id: 0x8300 base: 0xfed00000
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: video=vesa:ywrap,mtrr vga=788 initrd=/install.amd/gtk/initrd.gz rescue/enable=true -- quiet BOOT_IMAGE=/install.amd/vmlinuz
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes)
[ 0.995347] io scheduler deadline registered
[ 0.995347] io scheduler cfq registered (default)
[ 1.138295] pci 0000:01:05.0: Boot video device
[ 1.139686] PCI: Setting latency timer of device 0000:00:07.0 to 64
[ 1.139686] assign_interrupt_mode Found MSI capability
[ 1.474021] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 1
[ 1.474021] ohci_hcd 0000:00:12.0: irq 16, io mem 0xfe7fe000
[ 25.132175] usb usb7: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd
[ 25.132176] usb usb7: SerialNumber: 0000:00:14.5
[ 25.135829] ATIIXP: IDE controller (0x1002:0x439c rev 0x00) at PCI slot 0000:00:14.1
[ 25.135829] ACPI: PCI Interrupt 0000:00:14.1[A] -> GSI 16 (level, low) -> IRQ 16
[ 25.135829] ATIIXP: not 100% native mode: will probe irqs later
[ 25.135829] ide0: BM-DMA at 0xff00-0xff07
[ 25.135829] ide1: BM-DMA at 0xff08-0xff0f
[ 25.135829] Probing IDE interface ide0...
[ 25.520013] usb 4-3: new low speed USB device using ohci_hcd and address 3
[ 25.719571] usb 4-3: configuration #1 chosen from 1 choice
[ 25.719571] usb 4-3: Product: Optical USB Mouse
[ 27.099216] hdd: host max PIO4 wanted PIO255(auto-tune) selected PIO4
[ 27.099376] hdd: UDMA/100 mode selected
$ dmesg | grep -i -A 2 -B 2 -C 2 hd
[ 27.786575] hdc: 2930277168 sectors (1500301 MB), CHS=65535/255/63
[ 27.786575] hdc: cache flushes supported
[ 27.786575] hdc:<6>usbcore: registered new interface driver hiddev
[ 27.794889] input: Logitech Optical USB Mouse as /class/input/input2
[ 27.798646] hdc1
[ 27.842575] input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:13.1-3
[ 27.842589] usbcore: registered new interface driver usbhid
[ 267.035784] md: raid4 personality registered for level 4
[ 267.044188] md: md0 stopped.
[ 267.048185] md: bind<hdc1>
[ 267.057214] raid1: raid set md0 active with 1 out of 2 mirrors
[ 267.058653] device-mapper: uevent: version 1.0.3
$ dmesg | grep -i -A 2 -B 2 -C 2 sd
[ 0.000000] init_memory_mapping
[ 0.000000] DMI present.
[ 0.000000] ACPI: RSDP 000FB4F0, 0024 (r2 ACPIAM)
[ 0.000000] ACPI: XSDT CFF90100, 0054 (r1 112609 XSDT1132 20091126 MSFT 97)
[ 0.000000] ACPI: FACP CFF90290, 00F4 (r3 112609 FACP1132 20091126 MSFT 97)
[ 0.000000] ACPI Warning (tbfadt-0442): Optional field "Pm2ControlBlock" has zero address or length: 0000000000000000/1 [20080321]
[ 0.000000] ACPI: DSDT CFF90450, D100 (r1 A1391 A1391001 1 INTL 20060113)
[ 0.000000] ACPI: FACS CFFA8000, 0040
[ 0.000000] ACPI: APIC CFF90390, 007C (r1 112609 APIC1132 20091126 MSFT 97)
[ 0.000000] ACPI: OEMB CFFA8040, 0072 (r1 112609 OEMB1132 20091126 MSFT 97)
[ 0.000000] ACPI: HPET CFF9F450, 0038 (r1 112609 OEMHPET 20091126 MSFT 97)
[ 0.000000] ACPI: SSDT CFF9F490, 0458 (r1 A M I POWERNOW 1 AMD 1)
[ 0.000000] Scanning NUMA topology in Northbridge 24
[ 0.000000] No NUMA configuration found
[ 0.240015] PCI: Not using MMCONFIG.
[ 0.240015] PCI: Using configuration type 1 for base access
[ 0.240015] ACPI: EC: Look up EC in DSDT
[ 0.275639] ACPI: Interpreter enabled
[ 0.275642] ACPI: (supports S0 S1 S3 S4 S5)
J’ai toujours autant de mal à décoder tout cela.
Oui, bien sûr. Simplement, comme il y a plusieurs indices qui semblent le suggérer, je voudrais savoir s’il y a moyen d’approfondir cette piste : avant de chercher un moyen de faire faire une intervention sur Nantes, je voudrais éviter, autant que possible, que ce soit pour rien.
À bientôt.
Le Farfadet Spatial
