Les dernières nouvelles concernant le gel de la version « Testing » actuelle, future « Stable », la bien nomée SQUEEZE ![]()
Debian Project News - May 18th, 2010
Alexander Reichle-Schmehl
Squeeze freeze
Adam Barratt and the release team sent out an update on the status of
transitions, Release Critical bugs and a Timeline of the Squeeze freeze.
In short, we have a way to go before Squeeze is frozen and it is
difficult for the release team to estimate when Squeeze will get frozen.
Adam writes "In order to help us keep a clearer picture of which changes
still need to occur before we can freeze, we will be introducing a
'transition freeze' before the end of this month. If you have not yet
discussed your transition with the Release Team, please ensure that you
have done so before May 21st."
The release team is already working on some transitions now, like Qt4
and gnome-desktop, which are finished. The KDE team is working on KDE
4.4 with the goal of having as up-to-date and stable version of the KDE
suite as is possible. To quote Adam: "We're also close to completing the
evince / totem-pl-parser transition, which means we're well on the way
to have GNOME 2.30 in Squeeze."
"Even though the descending slope of theRC bug graph [8] is pretty
impressive [2], we still have about 400 RC bugs in Squeeze. Some of them
are waiting for packages to transition from unstable to testing, but
there's still a large number which need working on. On this every DD can
help out by NMUing packages which are currently affected by RC bugs.
Please remember that releasing is a collective effort and it is not
enough to just have your own packages RC-bug free (although it's a good
start) to be able to release. So, if you can help, please choose an RC
bug [9], fix it :-) and NMU it, possibly to the DELAYED queue so that
the maintainer can react if needed."
8 : http://bugs.debian.org/release-critical/
9 : http://bugs.debian.org/release-critical/debian/all.html
Par contre, je n’ai rien trouvé concernant la version du noyau… Personnellement, j’èspère que ce sera le 2.6.33(minimum) car il semblerait que la gestion des SSD y soit intégrée… à voir, donc.
Bonne journée à tous zé toutes,
Debcool
