ifconfig
[code]eth0 Link encap:Ethernet HWaddr 40:61:86:ae:cd:ac
Interruption:40
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 B) TX bytes:560 (560.0 B)
usb0 Link encap:Ethernet HWaddr de:75:cc:f3:67:4b
inet adr:192.168.77.188 Bcast:192.168.77.255 Masque:255.255.255.0
adr inet6: fe80::dc75:ccff:fef3:674b/64 Scope:Lien
RX packets:727 errors:0 dropped:0 overruns:0 frame:0
TX packets:729 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:533087 (520.5 KiB) TX bytes:187658 (183.2 KiB)
iwconfig
[code]lo no wireless extensions.
usb0 no wireless extensions.
pan0 no wireless extensions.
eth0 no wireless extensions.
dmesg | grep rt2
[ 6.540066] rt2800pci 0000:03:00.0: Refused to change power state, currently in D3
[ 6.540088] rt2800pci 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.540110] rt2800pci 0000:03:00.0: cache line size of 64 is not supported
[ 6.540116] rt2x00pci -> rt2x00pci_probe: Error - MWI not available.
[ 6.550362] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.560666] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.570993] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.581294] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.591582] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.601757] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.612040] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.622327] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.632627] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.642950] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.653293] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.663608] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.673840] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.684249] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.694565] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.704929] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.715440] phy0 -> rt2x00pci_regbusy_read: Error - Indirect register access failed: offset=0x00000580, value=0xffffffff
[ 6.715606] phy0 -> rt2800_init_eeprom: Error - Invalid RT chipset 0xffff detected.
[ 6.715727] phy0 -> rt2x00lib_probe_dev: Error - Failed to allocate device.
[ 6.716044] rt2800pci 0000:03:00.0: PCI INT A disabled
lsmod | grep rt
parport_pc 21895 0
parport 27018 3 parport_pc,ppdev,lp
rt2800pci 13496 0
rt2800lib 42925 1 rt2800pci
crc_ccitt 12331 1 rt2800lib
rt2x00pci 12721 1 rt2800pci
rt2x00lib 28947 3 rt2800pci,rt2800lib,rt2x00pci
mac80211 174497 3 rt2800lib,rt2x00pci,rt2x00lib
cfg80211 116717 2 rt2x00lib,mac80211
eeprom_93cx6 12423 1 rt2800pci
Le message de boot est assez peu encourageant =/
