je viens de remarquer qu’en lancant startx il m’indique une autre erreur :
[quote]# startx
xauth:  creating new authority file /root/.serverauth.1898
X: warning; process set to priority -1 instead of requested priority 0
X Window System Version 6.9.0 (Debian 6.9.0.dfsg.1-4 20060114230205 David Nusinow dnusinow@debian.org)
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: Linux 2.6.15-1-686 i686 [ELF]
Current Operating System: Linux debian-guillaume 2.6.8-2-386 #1 Tue Aug 16 12:46:35 UTC 2005 i686
Build Date: 14 January 2006
Before reporting problems, check wiki.X.Org
Module Loader present
OS Kernel: Linux version 2.6.8-2-386 (horms@tabatha.lab.ultramonkey.org) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 Tue Aug 16 12:46:35 UTC 2005
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Mar 20 15:43:13 2006
(==) Using config file: "/etc/X11/xorg.conf"
b VESA(0): No matching modes
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found[/b]
Please consult the The X.Org Foundation support
at wiki.X.Org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.
XIO:  fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
j’ai donc comparé à ce que j’avais ailleurs et sur une autre machine Suse identique, il utilise i810 au lieu de vesa, lancement de dpkg-reconfigure, changement du vesa en i810, re startx et :
[quote]# startx
xauth:  creating new authority file /root/.serverauth.2307
(==) Log file: “/var/log/Xorg.0.log”, Time: Mon Mar 20 15:50:43 2006
(==) Using config file: “/etc/X11/xorg.conf”
b GARTInit: Unable to open /dev/agpgart (No such file or directory)
(EE) I810(0): No Video BIOS modes for chosen depth.
Fatal server error:
at wiki.X.Org
for help.
c’est une vidéo intégrée mais n’ayant pas d’accès physique je ne peux vérifier les “choix” possible du BIOS (pour essayer de résoudre l’'erreur i810).
