Bonjours à tous,
Pour donner un coup de fouet à un vieux notebook je viens de franchir le cap Linux pour la première fois. Je suis novice et assez désorienté. Pardonnez un windowzien indécrottable…mais qui ne demande qu’à apprendre.
Pour des questions de config obsolète et l’envie de découvrir linux de la manière la plus simple j’ai installé Handylinux 1.5 sensé bien fonctionner sur les vieilles config.
La config d’ailleurs la voila :
Compaq Presario 902FRA
System information report, generated by Sysinfo: 10/05/2014 18:37:47
sourceforge.net/projects/gsysinfo
SYSTEM INFORMATION
Running Debian Linux, the 7.5 release.
GNOME: unknown (unknown)
Kernel version: 3.2.0-4-486 (#1 Debian 3.2.57-3)
GCC: no gcc detected
Xorg: 1.12.4 (17 December 2013 08:37:13PM) (17 December 2013 08:37:13PM)
Hostname: Corto
Uptime: 0 days 0 h 46 min
CPU INFORMATION
AuthenticAMD, Mobile AMD Athlon™ XP 2000+
Number of CPUs: 1
CPU clock currently at 1656.337 MHz with 256 KB cache
Numbering: family(6) model(8) stepping(1)
Bogomips: 3312.69
Flags: fpu vme de pse tsc msr pae mce cx8 sep mtrr pge mca cmov pat pse36 mmx fxsr sse syscall mp mmxext 3dnowext 3dnow
MEMORY INFORMATION
Total memory: 692 MB
Total swap: 997 MB
STORAGE INFORMATION
HARDWARE INFORMATION
MOTHERBOARD
Host bridge
Advanced Micro Devices [AMD] nee ATI RS100 AGP Bridge [IGP 320M] (rev 13)
PCI bridge(s)
Advanced Micro Devices [AMD] nee ATI PCI Bridge [IGP 320M] (rev 01) (prog-if 00 [Normal decode])
ISA bridge
ULi Electronics Inc. M1533/M1535/M1543 PCI to ISA Bridge [Aladdin IV/V/V+]
Subsystem: ULi Electronics Inc. ALi M1533 Aladdin IV/V ISA Bridge
IDE interface
ULi Electronics Inc. M5229 IDE (rev c4) (prog-if fa)
Subsystem: ULi Electronics Inc. M5229 IDE
GRAPHIC CARD
VGA controller
Advanced Micro Devices [AMD] nee ATI RS100 [Radeon IGP320M] (prog-if 00 [VGA controller])
Subsystem: Compaq Computer Corporation Device 00b0
SOUND CARD
Multimedia controller
ULi Electronics Inc. M5451 PCI AC-Link Controller Audio Device (rev 02)
NETWORK
Ethernet controller
Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 20)
Après l’installation j’ai constaté que ça ramait encore plus que sous xp !
En regardant dans le gestionnaire des tâches j’ai constaté qu’un processus prenait constamment entre 30 et 50 % du cpu même en idle !!!
le voici :
/usr/bin/X11/X -nolisten tcp - auth var/run/slim.auth vt07
apparemment c’est Xorg la “couche graphique” de linux…
En faisant des recherches j’ai constaté que je n’étais pas le seul à avoir des problèmes avec des vieilles carte ati :
https://www.debian-fr.org/vieille-ati-xorg-surcharge-cpu-normal-t36005.html#p364188
La personne conseil de modifier le fichier Xorg.conf…
Le problème c’est que chez moi le fichier n’existe pas et d’ailleurs je n’ai aucune idée sur comment le générer sur cette distrib ???
Sinon on conseil aussi de changer d’interface graphique. comment faire ?
Si qq a une idée pour régler ce problème…j’ai pas envie de retourner sur XP pour ça…
Merci et à bientôt,
