voilà le dmesg
EeeMona:/home/monaliza# dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-1-686 (Debian 2.6.26-5) (waldi@debian.org) (gcc version 4.1.3 20080623 (prerelease) (Debian 4.1.2-23)) #1 SMP Wed Sep 10 16:46:13 UTC 2008
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001f780000 (usable)
[ 0.000000] BIOS-e820: 000000001f780000 - 000000001f790000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001f790000 - 000000001f7d0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001f7d0000 - 000000001f7de000 (reserved)
[ 0.000000] BIOS-e820: 000000001f7e0000 - 000000001f800000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 503MB LOWMEM available.
[ 0.000000] found SMP MP-table at [c00ff780] 000ff780
[ 0.000000] Entering add_active_range(0, 0, 128896) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 128896
[ 0.000000] HighMem 128896 -> 128896
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 128896
[ 0.000000] On node 0 totalpages: 128896
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 975 pages used for memmap
[ 0.000000] Normal zone: 123825 pages, LIFO batch:31
[ 0.000000] HighMem zone: 0 pages used for memmap
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI present.
[ 0.000000] Intel MultiProcessor Specification v1.4
[ 0.000000] Virtual Wire compatibility mode.
[ 0.000000] MPTABLE: OEM ID: INTEL Product ID: <6>MPTABLE: Product ID: <6>MPTABLE: APIC at: 0xFEE00000
[ 0.000000] Processor #0 (Bootup-CPU)
[ 0.000000] I/O APIC #1 Version 32 at 0xFEC00000.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Processors: 1
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 1f800000:df600000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37960 bytes of per cpu data
[ 0.000000] NR_CPUS: 8, nr_cpu_ids: 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127889
[ 0.000000] Kernel command line: root=/dev/sda1 ro quiet acpi=off
[ 0.000000] mapped APIC to ffffb000 (fee00000)
[ 0.000000] mapped IOAPIC to ffffa000 (fec00000)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 2048 (order: 11, 8192 bytes)
[ 0.000000] Detected 630.082 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.004000] Memory: 501580k/515584k available (1768k kernel code, 13492k reserved, 749k data, 244k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xe0000000 - 0xff7fe000 ( 503 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xdf780000 ( 503 MB)
[ 0.004000] .init : 0xc037d000 - 0xc03ba000 ( 244 kB)
[ 0.004000] .data : 0xc02ba033 - 0xc0375620 ( 749 kB)
[ 0.004000] .text : 0xc0100000 - 0xc02ba033 (1768 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084318] Calibrating delay using timer specific routine.. 1262.32 BogoMIPS (lpj=2524641)
[ 0.084409] Security Framework initialized
[ 0.084422] SELinux: Disabled at boot.
[ 0.084432] Capability LSM initialized
[ 0.084468] Mount-cache hash table entries: 512
[ 0.084825] Initializing cgroup subsys ns
[ 0.084834] Initializing cgroup subsys cpuacct
[ 0.084843] Initializing cgroup subsys devices
[ 0.084890] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.084898] CPU: L2 cache: 512K
[ 0.084910] Intel machine check architecture supported.
[ 0.084923] Intel machine check reporting enabled on CPU#0.
[ 0.084950] Checking 'hlt' instruction... OK.
[ 0.101069] SMP alternatives: switching to UP code
[ 0.114970] Freeing SMP alternatives: 16k freed
[ 0.115184] ExtINT not setup in hardware but reported by MP table
[ 0.115287] ENABLING IO-APIC IRQs
[ 0.115556] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.155309] CPU0: Intel(R) Celeron(R) M processor 900MHz stepping 08
[ 0.264016] Brought up 1 CPUs
[ 0.264016] Total of 1 processors activated (1262.32 BogoMIPS).
[ 0.264016] CPU0 attaching sched-domain:
[ 0.264016] domain 0: span 0
[ 0.264016] groups: 0
[ 0.264016] net_namespace: 660 bytes
[ 0.264016] Booting paravirtualized kernel on bare hardware
[ 0.264016] NET: Registered protocol family 16
[ 0.264016] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=5
[ 0.264016] PCI: Using configuration type 1 for base access
[ 0.264016] Setting up standard PCI resources
[ 0.280964] ACPI: Interpreter disabled.
[ 0.280975] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.281056] pnp: PnP ACPI: disabled
[ 0.281067] PnPBIOS: Scanning system for PnP BIOS support...
[ 0.281132] PnPBIOS: Found PnP BIOS installation structure at 0xc00f7810
[ 0.281141] PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x88ca, dseg 0xf0000
[ 0.282852] PnPBIOS: 14 nodes reported by PnP BIOS; 14 recorded by driver
[ 0.283558] PCI: Probing PCI hardware
[ 0.283567] PCI: Probing PCI hardware (bus 00)
[ 0.284740] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.284757] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
[ 0.284767] pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
[ 0.285433] PCI: Transparent bridge - 0000:00:1e.0
[ 0.287971] PCI: Using IRQ router PIIX/ICH [8086/2641] at 0000:00:1f.0
[ 0.288005] PCI->APIC IRQ transform: 0000:00:02.0[A] -> IRQ 16
[ 0.288017] PCI->APIC IRQ transform: 0000:00:1b.0[A] -> IRQ 16
[ 0.288042] PCI->APIC IRQ transform: 0000:00:1c.0[A] -> IRQ 16
[ 0.288051] PCI->APIC IRQ transform: 0000:00:1c.1[B] -> IRQ 17
[ 0.288060] PCI->APIC IRQ transform: 0000:00:1c.2[C] -> IRQ 18
[ 0.288069] PCI->APIC IRQ transform: 0000:00:1d.0[A] -> IRQ 23
[ 0.288078] PCI->APIC IRQ transform: 0000:00:1d.1[B] -> IRQ 19
[ 0.288087] PCI->APIC IRQ transform: 0000:00:1d.2[C] -> IRQ 18
[ 0.288097] PCI->APIC IRQ transform: 0000:00:1d.3[D] -> IRQ 16
[ 0.288105] PCI->APIC IRQ transform: 0000:00:1d.7[A] -> IRQ 23
[ 0.288119] PCI->APIC IRQ transform: 0000:00:1f.2[B] -> IRQ 19
[ 0.288128] PCI->APIC IRQ transform: 0000:00:1f.3[B] -> IRQ 19
[ 0.288138] PCI->APIC IRQ transform: 0000:03:00.0[A] -> IRQ 17
[ 0.288147] PCI->APIC IRQ transform: 0000:01:00.0[A] -> IRQ 18
[ 0.288996] hpet clockevent registered
[ 0.289009] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.289022] hpet0: 3 64-bit timers, 14318180 Hz
[ 0.290127] system 00:00: iomem range 0x0-0x9fbff could not be reserved
[ 0.290136] system 00:00: iomem range 0x9fc00-0x9ffff could not be reserved
[ 0.290146] system 00:00: iomem range 0xe4000-0xfffff could not be reserved
[ 0.290155] system 00:00: iomem range 0x100000-0x1f77ffff could not be reserved
[ 0.290164] system 00:00: iomem range 0x1f780000-0x1f78ffff could not be reserved
[ 0.290173] system 00:00: iomem range 0x1f790000-0x1f7cffff could not be reserved
[ 0.290182] system 00:00: iomem range 0x1f7d0000-0x1f7ddfff could not be reserved
[ 0.290191] system 00:00: iomem range 0x1f7e0000-0x1f7fffff could not be reserved
[ 0.290201] system 00:00: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 0.290210] system 00:00: iomem range 0xfff80000-0xffffffff could not be reserved
[ 0.290244] system 00:0b: ioport range 0x4d0-0x4d1 has been reserved
[ 0.290252] system 00:0b: ioport range 0xcf8-0xcff could not be reserved
[ 0.290261] system 00:0b: ioport range 0x480-0x4bf has been reserved
[ 0.290269] system 00:0b: ioport range 0x800-0x87f has been reserved
[ 0.290277] system 00:0b: ioport range 0x400-0x41f has been reserved
[ 0.290286] system 00:0b: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.290302] system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.291388] PCI: Bridge: 0000:00:1c.0
[ 0.291394] IO window: disabled.
[ 0.291403] MEM window: disabled.
[ 0.291411] PREFETCH window: disabled.
[ 0.291422] PCI: Bridge: 0000:00:1c.1
[ 0.291426] IO window: disabled.
[ 0.291436] MEM window: 0xfbf00000-0xfbffffff
[ 0.291443] PREFETCH window: disabled.
[ 0.291454] PCI: Bridge: 0000:00:1c.2
[ 0.291458] IO window: disabled.
[ 0.291467] MEM window: 0xf8000000-0xfbefffff
[ 0.291476] PREFETCH window: 0x00000000f0000000-0x00000000f6ffffff
[ 0.291488] PCI: Bridge: 0000:00:1e.0
[ 0.291492] IO window: disabled.
[ 0.291501] MEM window: disabled.
[ 0.291508] PREFETCH window: disabled.
[ 0.291551] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 0.291583] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 0.291616] PCI: Setting latency timer of device 0000:00:1c.2 to 64
[ 0.291635] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 0.291691] NET: Registered protocol family 2
[ 0.291934] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.292479] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.292748] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.293018] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.293025] TCP reno registered
[ 0.293285] NET: Registered protocol family 1
[ 0.293603] checking if image is initramfs...<7>Switched to high resolution mode on CPU 0
[ 0.985426] it is
[ 1.735608] Freeing initrd memory: 5765k freed
[ 1.737240] audit: initializing netlink socket (disabled)
[ 1.737279] type=2000 audit(1223135321.736:1): initialized
[ 1.737564] Total HugeTLB memory allocated, 0
[ 1.737795] VFS: Disk quotas dquot_6.5.1
[ 1.737867] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.737962] msgmni has been set to 991
[ 1.738280] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.738290] io scheduler noop registered
[ 1.738295] io scheduler anticipatory registered
[ 1.738301] io scheduler deadline registered
[ 1.738336] io scheduler cfq registered (default)
[ 1.738369] pci 0000:00:02.0: Boot video device
[ 1.766678] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 1.766728] assign_interrupt_mode Found MSI capability
[ 1.766788] Allocate Port Service[0000:00:1c.0:pcie00]
[ 1.766902] Allocate Port Service[0000:00:1c.0:pcie02]
[ 1.767079] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 1.767129] assign_interrupt_mode Found MSI capability
[ 1.767180] Allocate Port Service[0000:00:1c.1:pcie00]
[ 1.767281] Allocate Port Service[0000:00:1c.1:pcie02]
[ 1.767451] PCI: Setting latency timer of device 0000:00:1c.2 to 64
[ 1.767499] assign_interrupt_mode Found MSI capability
[ 1.767550] Allocate Port Service[0000:00:1c.2:pcie00]
[ 1.767651] Allocate Port Service[0000:00:1c.2:pcie02]
[ 1.768005] isapnp: Scanning for PnP cards...
[ 2.122186] isapnp: No Plug & Play device found
[ 2.126961] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 2.131867] brd: module loaded
[ 2.132178] PNP: PS/2 Controller [PNP0303,PNP0f13] at 0x60,0x64 irq 1,12
[ 2.168020] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.168035] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.168518] mice: PS/2 mouse device common for all mice
[ 2.170912] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 2.170946] rtc0: alarms up to one day
[ 2.171050] cpuidle: using governor ladder
[ 2.171057] cpuidle: using governor menu
[ 2.171069] No iBFT detected.
[ 2.172182] TCP cubic registered
[ 2.172191] NET: Registered protocol family 17
[ 2.172207] Using IPI No-Shortcut mode
[ 2.172537] registered taskstats version 1
[ 2.172701] rtc_cmos 00:04: setting system clock to 2008-10-04 15:48:43 UTC (1223135323)
[ 2.172701] Freeing unused kernel memory: 244k freed
[ 2.193842] input: AT Translated Set 2 keyboard as /class/input/input0
[ 2.414755] thermal: Unknown symbol acpi_processor_set_thermal_limit
[ 3.203279] usbcore: registered new interface driver usbfs
[ 3.203351] usbcore: registered new interface driver hub
[ 3.203440] usbcore: registered new device driver usb
[ 3.223001] USB Universal Host Controller Interface driver v3.0
[ 3.223108] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 3.223118] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.223353] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 3.223401] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000e400
[ 3.223609] usb usb1: configuration #1 chosen from 1 choice
[ 3.223683] hub 1-0:1.0: USB hub found
[ 3.223702] hub 1-0:1.0: 2 ports detected
[ 3.324374] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.324387] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.324396] usb usb1: Product: UHCI Host Controller
[ 3.324402] usb usb1: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.324408] usb usb1: SerialNumber: 0000:00:1d.0
[ 3.324502] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[ 3.324513] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.324582] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 3.324627] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e480
[ 3.324825] usb usb2: configuration #1 chosen from 1 choice
[ 3.324902] hub 2-0:1.0: USB hub found
[ 3.324920] hub 2-0:1.0: 2 ports detected
[ 3.413714] SCSI subsystem initialized
[ 3.436939] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.436951] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.436960] usb usb2: Product: UHCI Host Controller
[ 3.436966] usb usb2: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.436972] usb usb2: SerialNumber: 0000:00:1d.1
[ 3.437076] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[ 3.437087] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.437157] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 3.437204] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e800
[ 3.437415] usb usb3: configuration #1 chosen from 1 choice
[ 3.437493] hub 3-0:1.0: USB hub found
[ 3.437510] hub 3-0:1.0: 2 ports detected
[ 3.540297] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.540309] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.540317] usb usb3: Product: UHCI Host Controller
[ 3.540323] usb usb3: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.540329] usb usb3: SerialNumber: 0000:00:1d.2
[ 3.540420] PCI: Setting latency timer of device 0000:00:1d.3 to 64
[ 3.540432] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 3.540499] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
[ 3.540546] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000e880
[ 3.540750] usb usb4: configuration #1 chosen from 1 choice
[ 3.540830] hub 4-0:1.0: USB hub found
[ 3.540847] hub 4-0:1.0: 2 ports detected
[ 3.550117] libata version 3.00 loaded.
[ 3.644372] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.644383] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.644392] usb usb4: Product: UHCI Host Controller
[ 3.644398] usb usb4: Manufacturer: Linux 2.6.26-1-686 uhci_hcd
[ 3.644404] usb usb4: SerialNumber: 0000:00:1d.3
[ 3.646539] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 3.646552] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 3.646644] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 3.650573] ehci_hcd 0000:00:1d.7: debug port 1
[ 3.650585] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 3.650605] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf7eb7c00
[ 3.664053] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 3.664282] usb usb5: configuration #1 chosen from 1 choice
[ 3.664373] hub 5-0:1.0: USB hub found
[ 3.664401] hub 5-0:1.0: 8 ports detected
[ 3.768298] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.768310] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.768318] usb usb5: Product: EHCI Host Controller
[ 3.768324] usb usb5: Manufacturer: Linux 2.6.26-1-686 ehci_hcd
[ 3.768330] usb usb5: SerialNumber: 0000:00:1d.7
[ 3.768968] ahci 0000:00:1f.2: version 3.0
[ 3.769034] ahci: probe of 0000:00:1f.2 failed with error -22
[ 3.774719] ata_piix 0000:00:1f.2: version 2.12
[ 3.774748] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[ 3.774832] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 3.774961] scsi0 : ata_piix
[ 3.775159] scsi1 : ata_piix
[ 3.775236] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 3.775244] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 4.036023] usb 5-5: new high speed USB device using ehci_hcd and address 2
[ 4.108414] ata2.00: ATA-4: SILICONMOTION SM223AC, , max UDMA/66
[ 4.108424] ata2.00: 7815024 sectors, multi 0: LBA
[ 4.124384] ata2.00: configured for UDMA/66
[ 4.124654] scsi 1:0:0:0: Direct-Access ATA SILICONMOTION SM n/a PQ: 0 ANSI: 5
[ 4.145670] Uniform Multi-Platform E-IDE driver
[ 4.145683] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 4.169309] usb 5-5: configuration #1 chosen from 1 choice
[ 4.169758] usb 5-5: New USB device found, idVendor=0951, idProduct=1606
[ 4.169767] usb 5-5: New USB device strings: Mfr=1, Product=2, SerialNumber=4
[ 4.169775] usb 5-5: Product: UB6225
[ 4.169780] usb 5-5: Manufacturer: ENE
[ 4.169785] usb 5-5: SerialNumber: 146030377350
[ 4.198117] Driver 'sd' needs updating - please use bus_type methods
[ 4.198348] sd 1:0:0:0: [sda] 7815024 512-byte hardware sectors (4001 MB)
[ 4.198393] sd 1:0:0:0: [sda] Write Protect is off
[ 4.198401] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.198472] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4.198619] sd 1:0:0:0: [sda] 7815024 512-byte hardware sectors (4001 MB)
[ 4.198658] sd 1:0:0:0: [sda] Write Protect is off
[ 4.198666] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.198735] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4.198747] sda: sda1
[ 4.200067] sd 1:0:0:0: [sda] Attached SCSI disk
[ 4.261906] Initializing USB Mass Storage driver...
[ 4.262109] scsi2 : SCSI emulation for USB Mass Storage devices
[ 4.262282] usbcore: registered new interface driver usb-storage
[ 4.262292] USB Mass Storage support registered.
[ 4.266545] usb-storage: device found at 2
[ 4.266555] usb-storage: waiting for device to settle before scanning
[ 4.406045] kjournald starting. Commit interval 5 seconds
[ 4.406079] EXT3-fs: mounted filesystem with ordered data mode.
[ 5.083633] udevd version 125 started
[ 7.020875] Linux agpgart interface v0.103
[ 7.026505] agpgart: Detected an Intel 915GM Chipset.
[ 7.026839] agpgart: Detected 7932K stolen memory.
[ 7.058600] agpgart: AGP aperture is 256M @ 0xd0000000
[ 7.064091] Atheros(R) L2 Ethernet Driver - version 2.0.5
[ 7.064100] Copyright (c) 2007 Atheros Corporation.
[ 7.064188] PCI: Setting latency timer of device 0000:03:00.0 to 64
[ 7.192565] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 7.216872] ath_hal: module license 'Proprietary' taints kernel.
[ 7.222225] AR5210, AR5211, AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2133, RF2425, RF2417)
[ 7.710680] PCI: Setting latency timer of device 0000:01:00.0 to 64
[ 8.205309] MadWifi: ath_attach: Switching rfkill capability off.
[ 8.241975] input: PC Speaker as /class/input/input1
[ 8.960104] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.03 (30-Apr-2008)
[ 8.960278] iTCO_wdt: Found a ICH6-M TCO device (Version=2, TCOBASE=0x0860)
[ 8.960337] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.014548] Error: Driver 'pcspkr' is already registered, aborting...
[ 9.264250] usb-storage: device scan complete
[ 9.264865] scsi 2:0:0:0: Direct-Access USB2.0 CardReader SD0 0100 PQ: 0 ANSI: 0
[ 9.266893] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 9.295879] intel_rng: FWH not detected
[ 9.865203] wifi0: Atheros AR2425 chip found (MAC 14.2, PHY SChip 7.0, Radio 10.2)
[ 9.875244] ath_pci: wifi0: Atheros 5424/2424: mem=0xfbef0000, irq=18
[ 10.232552] Synaptics Touchpad, model: 1, fw: 6.5, id: 0x1c0b1, caps: 0xa04751/0xa00000
[ 10.319102] input: SynPS/2 Synaptics TouchPad as /class/input/input2
[ 10.984550] EXT3 FS on sda1, internal journal
[ 12.445657] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 16.380072] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 19.961458] [drm] Initialized drm 1.1.0 20060810
[ 19.970416] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 19.970642] [drm] Initialized i915 1.6.0 20060119 on minor 0
[ 68.583245] NET: Registered protocol family 10
[ 68.584493] lo: Disabled Privacy Extensions
[ 78.920019] eth0: no IPv6 routers present
[ 78.936015] ath0: no IPv6 routers present
[ 363.448402] xfce4-cpufreq-p[1977]: segfault at 65636674 ip b76926b2 sp bff63040 error 4 in libc-2.7.so[b7622000+155000]
[ 384.800039] ath0: no IPv6 routers present
[ 385.157882] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 385.158428] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 385.158561] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 395.880036] eth0: no IPv6 routers present
[ 492.856015] ath0: no IPv6 routers present
[ 533.483516] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 533.483999] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 533.484150] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 543.812014] eth0: no IPv6 routers present
[ 610.565367] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 610.566143] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 610.566254] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 618.740053] ath0: no IPv6 routers present
[ 620.624019] eth0: no IPv6 routers present
[ 645.880037] ath0: no IPv6 routers present
[ 660.695180] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 660.695672] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 660.695780] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 664.312030] ath0: no IPv6 routers present
[ 671.440017] eth0: no IPv6 routers present
[ 718.675527] ADDRCONF(NETDEV_UP): ath0: link is not ready
[ 720.847279] ADDRCONF(NETDEV_UP): ath0: link is not ready
[ 721.205572] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 721.206044] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 721.206154] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 722.782653] ADDRCONF(NETDEV_UP): ath0: link is not ready
[ 724.627485] ADDRCONF(NETDEV_UP): ath0: link is not ready
[ 731.616018] eth0: no IPv6 routers present
[ 826.048780] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 826.049371] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 826.049485] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 836.888045] eth0: no IPv6 routers present
[ 901.553981] atl2: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 901.554604] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 901.554717] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 912.488018] eth0: no IPv6 routers present
J’ai réussi à installer Wicd à partir du dépôt, il voit la livebox, je rentre la clé wpa mais ne parvient pas à se connecter. Je lui ai indiqué l’interface ath0 et madwifi comme pilote wpa mais pareil…
Comment faire pour la fréquence??? éventuellement la faire varier en fonction de l’utilisation…
Merci.
