Distro Debian Squeeze //installé en net-install en usb (v.6.0.4) téléchargé via cdimage …
kernel 2.6.32-5-686 //uname -r
#$ lspci
00:00.0 Host bridge: nVidia Corporation MCP73 Host Bridge (rev a2)
00:00.1 RAM memory: nVidia Corporation nForce 630i memory controller (rev a2)
00:01.0 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.1 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.2 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.3 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.4 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.5 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:01.6 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:02.0 RAM memory: nVidia Corporation nForce 630i memory controller (rev a1)
00:03.0 ISA bridge: nVidia Corporation MCP73 LPC Bridge (rev a2)
00:03.1 SMBus: nVidia Corporation MCP73 SMBus (rev a1)
00:03.2 RAM memory: nVidia Corporation MCP73 Memory Controller (rev a1)
00:03.4 RAM memory: nVidia Corporation MCP73 Memory Controller (rev a1)
00:04.0 USB Controller: nVidia Corporation GeForce 7100/nForce 630i USB (rev a1)
00:04.1 USB Controller: nVidia Corporation MCP73 [nForce 630i] USB 2.0 Controller (EHCI) (rev a1)
00:08.0 IDE interface: nVidia Corporation MCP73 IDE (rev a1)
00:09.0 Audio device: nVidia Corporation MCP73 High Definition Audio (rev a1)
00:0a.0 PCI bridge: nVidia Corporation MCP73 PCI Express bridge (rev a1)
00:0b.0 PCI bridge: nVidia Corporation MCP73 PCI Express bridge (rev a1)
00:0c.0 PCI bridge: nVidia Corporation MCP73 PCI Express bridge (rev a1)
00:0e.0 SATA controller: nVidia Corporation GeForce 7100/nForce 630i SATA (rev a2)
00:0f.0 Ethernet controller: nVidia Corporation MCP73 Ethernet (rev a2)
00:10.0 VGA compatible controller: nVidia Corporation C73 [GeForce 7100 / nForce 630i] (rev a2)
lsusb
Bus 002 Device 002: ID 192f:0416 Avago Technologies, Pte.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 0bda:0151 Realtek Semiconductor Corp. Mass Storage Device (Multicard Reader)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
J’ai installé tout ce que je pouvait installer en esound alsa et pulseaudio
Dans Préférence du son onglet Matériel :
DIGITAL (HDMI) STEREO OUTPUT
Et dans alsamixer le numérique est coché à ses 3 endroit
La carte est GeForce 7100 / nForce 630i tout les pilotes proprio fonctionnent
en graphique mais pas en son
J’était sur ubuntu avant n’importe quel version fonctionnait en son avec seulement le pilote suivant : Linux Display Driver - x86 285.0509 5.10.2011
Si quelqu’un avait cette carte ou s’avait ce qu’il manque à debian (paquet(s)) lorsque l’on souhaite avoir du son en HDMI , merci de m’aider dans ce cas.
INK NOISE pour ce device
Sur que c’est un bout de code créer par
