Installation compiz sur debian etch
j’avance mais je ne vois pas ce qu’il faut que je change
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "nVidia Corporation NV17 [GeForce4 MX 420]"
Driver "nv"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "HP D8904"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation NV17 [GeForce4 MX 420]"
Monitor "HP D8904"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
option “Composite” "Enable"
EndSection
au secours j’ai marqué compiz --replacegconf
et j’ai plus de bordure de fenetre, juste un bureau
merci a vous tous de m’aider
dejà ton fichier de configuration n’indique pas le bon pilote
il faut mettre “nvidia”
et il te manque beaucoup d’options
reprends le tuto “nvidia facile” dans trucs et astuces
Grillé par misaine…
ça veut dire que la 3D ne fonctionne pas. Ce n’est pas étonnant quand on voit le driver utilisé :
[quote=“gigi42”]Section "Device"
Driver "nv"
BusID "PCI:1:0:0"
EndSection[/quote]
Commence déjà par installer les pilotes proprios nVidia si tu veux la 3D. L’ami debianhadic a fait un excellent tuto dans truc&astuces.
:exclamation: nvidia s’installe à la manière Debian, comme l’a décrit debianhadic, pas de *.run téléchargé sur le site de NVIDIA !!! :exclamation:
pour avancer…
[quote]Configuration avancée
Support de Compiz-fusion
Compiz nécessite le support du rendu “GLX_texture_from_pixmap”, désormais inclus dans le driver nvidia.
Pour l’activer, ajoutez ces deux options:
Section "Device"
Driver “nvidia”
Option “TripleBuffer” "True"
Option "AddARGBGLXVisuals"
EndSection
Option “Composite” "Enable"
EndSection
extrait de l’excellent tuto du wiki d’archlinux qu’il faudra qu’un jour je traduise en language debian
je ne mets pas de lien pour eviter que les debutants fassent du copié/collé des commandes pacman
j’ai changer
Section "Device"
Driver "nvidia"
BusID "PCI:1:0:0"
Option “AddARGBGLXVisuals”
penses tu que cela va marcher maintenant?
merci pour tes conseil
[quote=“gigi42”]
merci pour tes conseil[/quote]
Ba essaye!
Moi, je ne pense pas mais qui sais…
fiou!!! j’ai failli tous perdre heureusement qu’au beaux erts le president de linux m’avais donner la commande qui sauve la vie!!! dpkg-reconfigure xserver-xorg
donc j’en conclu que sa a pas marcher!!!
le temp que je me remette des emotions et je m’y remet mais merci tout de meme
linux demande de la rigueur
tant que tu ne diras pas ce que tu as fait exactement , on ne pourra pas t’aider…
là moi j’abandonne…
beh j’avais enlevé nv pour marquer nvidia et puis j’avais marquer option etc… c’est tous ce que j’ais fais
et tu n’as pas installé le driver!!??
comme anatomicJC te l’avais dit
mais normalement j’ai deja nvidia je l’avais installé il y a une semaine des paquets syneptic
Compiz-fusion c’est comme un supplice de tantale, tu vois, on le veux, mais on l’aura jamais! Et ce peu importe les efforts que ty y mets! Moi ça fais 2 semaines, mais ça sera comme ça pour l’éternité! Mouahaha!
viewtopic.php?f=8&t=13604
Personnellement je te conseillerai de reprendre à zéro en suivant le tuto que l’on t’a indiqué plus haut sur les pilotes nvidia car à force tu vas t’emmêler les pinceaux.
Je veut pas faire mon rabats joies mais les effets de compiz te sont-il vraiment indispensable sur ton ordi ou c’est juste pour en jeté :smt002 moi j’en utilisé que deux le zoom et le déplacement latérale des bureaux que je fais plus simplement sous fluxbox :stuck_out_tongue:
d’accord j’avoue c’est pour en jeté!! mais je le veux vrément!!!je l’ai vu marcher c’est exellent!!!mais je suis en train de péter un cable !!!
Donc je serais toi je recommencerai tous à zéro en expliquant bien toutes les étapes que tu auras faites jusqu’au point noir de ta tentative car là je crois que tu vas plus pouvoir t’y retrouver avec tous ce que tu as fait :smt002
d’accord mais pour recommencer du debut
je doi tous supprimer ou c’est pas un probleme?
je reinstal mais nvidia n’ai pas trouvé
debian:/home/toto# lspci
00:00.0 Host bridge: Intel Corporation 82845 845 (Brookdale) Chipset Host Bridge (rev 03)
00:01.0 PCI bridge: Intel Corporation 82845 845 (Brookdale) Chipset AGP Bridge ( rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 12)
00:1f.0 ISA bridge: Intel Corporation 82801BA ISA Bridge (LPC) (rev 12)
00:1f.1 IDE interface: Intel Corporation 82801BA IDE U100 (rev 12)
00:1f.2 USB Controller: Intel Corporation 82801BA/BAM USB (Hub #1) (rev 12)
00:1f.3 SMBus: Intel Corporation 82801BA/BAM SMBus (rev 12)
00:1f.4 USB Controller: Intel Corporation 82801BA/BAM USB (Hub #2) (rev 12)
00:1f.5 Multimedia audio controller: Intel Corporation 82801BA/BAM AC’97 Audio ( rev 12)
01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 420] (re v a3)
02:08.0 Ethernet controller: Intel Corporation 82801BA/BAM/CA/CAM Ethernet Contr oller (rev 03)
02:0d.0 Communication controller: Intel Corporation 536EP Data Fax Modem
debian:/home/toto# apt-get install module-assistant
Paquets suggérés :
build-essential
module-assistant
0 mis à jour, 1 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 74,9ko dans les archives.
Après dépaquetage, 414ko d’espace disque supplémentaires seront utilisés.
Réception de : 1 ftp.fr.debian.org etch/main module-assistant 0.10.8 [74,9kB]
74,9ko réceptionnés en 0s (259ko/s)
Sélection du paquet module-assistant précédemment désélectionné.
(Lecture de la base de données… 94423 fichiers et répertoires déjà installés.)
Dépaquetage de module-assistant (à partir de …/module-assistant_0.10.8_all.deb) …
Paramétrage de module-assistant (0.10.8)
debian:/home/toto# m-a prepare
Récupération des sources du noyau de la version : 2.6.18-6-686
apt-get install linux-headers-2.6.18-6-686
linux-headers-2.6.18-6 linux-headers-2.6.18-6-686
0 mis à jour, 2 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 3515ko dans les archives.
Après dépaquetage, 25,6Mo d’espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer [O/n] ? O
Réception de : 1 ftp.fr.debian.org etch/main linux-headers-2.6.18-6 2.6.18.dfsg.1-23etch1 [3228kB]
Réception de : 2 ftp.fr.debian.org etch/main linux-headers-2.6.18-6-686 2.6.18.dfsg.1-23etch1 [287kB]
3515ko réceptionnés en 1s (2100ko/s)
Sélection du paquet linux-headers-2.6.18-6 précédemment désélectionné.
(Lecture de la base de données… 94470 fichiers et répertoires déjà installés.)
Dépaquetage de linux-headers-2.6.18-6 (à partir de …/linux-headers-2.6.18-6_2.6.18.dfsg.1-23etch1_i386.deb) …
Sélection du paquet linux-headers-2.6.18-6-686 précédemment désélectionné.
Dépaquetage de linux-headers-2.6.18-6-686 (à partir de …/linux-headers-2.6.18-6-686_2.6.18.dfsg.1-23etch1_i386.deb) …
Paramétrage de linux-headers-2.6.18-6 (2.6.18.dfsg.1-23etch1) …
Paramétrage de linux-headers-2.6.18-6-686 (2.6.18.dfsg.1-23etch1) …
Création du lien symbolique…
apt-get install build-essential
g++ g+±4.1 gcc libstdc++6-4.1-dev
Paquets suggérés :
gcc-4.1-doc lib64stdc++6 manpages-dev autoconf automake1.9 libtool flex bison
gcc-doc libstdc++6-4.1-doc
build-essential g++ g+±4.1 gcc libstdc++6-4.1-dev
0 mis à jour, 5 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 4262ko dans les archives.
Après dépaquetage, 16,3Mo d’espace disque supplémentaires seront utilisés.
Réception de : 1 ftp.fr.debian.org etch/main gcc 4:4.1.1-15 [5052B]
Réception de : 2 ftp.fr.debian.org etch/main libstdc++6-4.1-dev 4.1.1-21 [1634kB]
Réception de : 3 ftp.fr.debian.org etch/main g+±4.1 4.1.1-21 [2615kB]
Réception de : 4 ftp.fr.debian.org etch/main g++ 4:4.1.1-15 [1360B]
Réception de : 5 ftp.fr.debian.org etch/main build-essential 11.3 [6982B]
4262ko réceptionnés en 2s (2042ko/s)
Sélection du paquet gcc précédemment désélectionné.
(Lecture de la base de données… 101911 fichiers et répertoires déjà installés.)Dépaquetage de gcc (à partir de …/gcc_4%3a4.1.1-15_i386.deb) …
Sélection du paquet libstdc++6-4.1-dev précédemment désélectionné.
Dépaquetage de libstdc++6-4.1-dev (à partir de …/libstdc++6-4.1-dev_4.1.1-21_i386.deb) …
Sélection du paquet g+±4.1 précédemment désélectionné.
Dépaquetage de g+±4.1 (à partir de …/g+±4.1_4.1.1-21_i386.deb) …
Sélection du paquet g++ précédemment désélectionné.
Dépaquetage de g++ (à partir de …/g++_4%3a4.1.1-15_i386.deb) …
Sélection du paquet build-essential précédemment désélectionné.
Dépaquetage de build-essential (à partir de …/build-essential_11.3_i386.deb) …
Paramétrage de gcc (4.1.1-15) …
Paramétrage de libstdc++6-4.1-dev (4.1.1-21) …
Paramétrage de g+±4.1 (4.1.1-21) …
Paramétrage de g++ (4.1.1-15) …
Paramétrage de build-essential (11.3) …
Fait.
debian:/home/toto# m-a a-i -i nvidia-kernel-source
Données de 1 paquets mises à jour
En-têtes du noyau disponibles dans /lib/modules/2.6.18-6-686/build
apt-get-y install build-essential
Fait.
download
E: Impossible de trouver le paquet nvidia-kernel-source
Échec de l’installation des sources de nvidia-kernel-source.
Paquet ignoré. Vous devez peut-être ajouter quelque chose à sources.list, comme
les archives « contrib » et « non-free ».
Mise à jour des données de nvidia-kernel-source
debian:/home/toto# apt-get install nvidia-glx
Aucune version du paquet nvidia-glx n’est disponible, mais il existe dans la basede données. Cela signifie en général que le paquet est manquant, qu’il est devenu obsolète
ou qu’il n’est disponible que sur une autre source
E: Aucun paquet ne correspond au paquet nvidia-glx
debian:/home/toto#
