Ok, mais je préviens, c’est long… et je n’y vois pas les lignes concernant les modules.
Voyez si vous pouvez détecter des choses pas normales. C’est quoi ça le device mapper, par exemple, et cette adresse, et ce journal, que j’ai mis en gras? Et ce ramdisk?
y, caps: 0383fbff c1c3fbff 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000020
CPU: AMD Athlon™ XP 2400+ stepping 01
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Checking ‘hlt’ instruction… OK.
enabled ExtINT on CPU#0
ESR value before enabling vector: 00000080
ESR value after enabling vector: 00000000
ENABLING IO-APIC IRQs
init IO_APIC IRQs
IO-APIC (apicid-pin) 2-0, 2-16, 2-17, 2-18, 2-19, 2-20, 2-21, 2-22, 2-23 not connected.
…TIMER: vector=0x31 pin1=2 pin2=-1
Using local APIC timer interrupts.
calibrating APIC timer …
… CPU clock speed is 2029.0708 MHz.
… host bus clock speed is 270.0627 MHz.
checking if image is initramfs…it isn’t (ungzip failed); looks like an initrd
Freeing initrd memory: 3760k freed
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xfdaf1, last bus=1
PCI: Using configuration type 1
ACPI: Subsystem revision 20040326
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [_SB_.PCI0._PRT]
ACPI: Power Resource [URP1] (off)
ACPI: Power Resource [URP2] (off)
ACPI: Power Resource [FDDP] (off)
ACPI: Power Resource [LPTP] (off)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: the driver ‘system’ has been registered
PCI: Using ACPI for IRQ routing
ACPI: PCI interrupt 0000:00:05.0[A] -> GSI 16 (level, low) -> IRQ 16
ACPI: PCI interrupt 0000:00:06.0[?]: no GSI
ACPI: PCI interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 21
ACPI: PCI interrupt 0000:00:10.1[‘B’] -> GSI 21 (level, low) -> IRQ 21
ACPI: PCI interrupt 0000:00:10.2[C] -> GSI 21 (level, low) -> IRQ 21
ACPI: PCI interrupt 0000:00:10.3[D] -> GSI 21 (level, low) -> IRQ 21
ACPI: PCI interrupt 0000:00:11.1[A]: no GSI
ACPI: PCI interrupt 0000:00:12.0[A] -> GSI 23 (level, low) -> IRQ 23
ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
number of MP IRQ sources: 15.
number of IO-APIC #2 registers: 24.
testing the IO APIC…
IO APIC #2…
… register #00: 02000000
… : physical APIC id: 02
… : Delivery Type: 0
… : LTS : 0
… register #01: 00178003
… : max redirection entries: 0017
… : PRQ implemented: 1
… : IO APIC version: 0003
… IRQ redirection table:
NR Log Phy Mask Trig IRR Pol Stat Dest Deli Vect:
00 000 00 1 0 0 0 0 0 0 00
01 001 01 0 0 0 0 0 1 1 39
02 001 01 0 0 0 0 0 1 1 31
03 001 01 0 0 0 0 0 1 1 41
04 001 01 0 0 0 0 0 1 1 49
05 001 01 0 0 0 0 0 1 1 51
06 001 01 0 0 0 0 0 1 1 59
07 001 01 0 0 0 0 0 1 1 61
08 001 01 0 0 0 0 0 1 1 69
09 001 01 0 1 0 1 0 1 1 71
0a 001 01 0 0 0 0 0 1 1 79
0b 001 01 0 0 0 0 0 1 1 81
0c 001 01 0 0 0 0 0 1 1 89
0d 001 01 0 0 0 0 0 1 1 91
0e 001 01 0 0 0 0 0 1 1 99
0f 001 01 0 0 0 0 0 1 1 A1
10 001 01 1 1 0 1 0 1 1 A9
11 000 00 1 0 0 0 0 0 0 00
12 000 00 1 0 0 0 0 0 0 00
13 000 00 1 0 0 0 0 0 0 00
14 000 00 1 0 0 0 0 0 0 00
15 001 01 1 1 0 1 0 1 1 B1
16 000 00 1 0 0 0 0 0 0 00
17 001 01 1 1 0 1 0 1 1 B9
IRQ to pin mappings:
IRQ0 -> 0:2
IRQ1 -> 0:1
IRQ3 -> 0:3
IRQ4 -> 0:4
IRQ5 -> 0:5
IRQ6 -> 0:6
IRQ7 -> 0:7
IRQ8 -> 0:8
IRQ9 -> 0:9
IRQ10 -> 0:10
IRQ11 -> 0:11
IRQ12 -> 0:12
IRQ13 -> 0:13
IRQ14 -> 0:14
IRQ15 -> 0:15
IRQ16 -> 0:16
IRQ21 -> 0:21
IRQ23 -> 0:23
… done.
PCI: Device 00:30 not found by BIOS
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
Initializing Cryptographic API
PCI: Via IRQ fixup for 0000:00:10.1, from 11 to 5
PCI: Via IRQ fixup for 0000:00:10.0, from 11 to 5
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
mice: PS/2 mouse device common for all mice
serio: i8042 AUX port at 0x60,0x64 irq 12
input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
EISA: Probing bus 0 at eisa0
NET: Registered protocol family 2
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: (supports S0 S1 S4 S5)
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 3760 blocks [1 disk] into ram disk…
|/-\|/-\|/[…]/-\|/-\|/-\|/-\|/-\|/-done.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 224k freed
SCSI subsystem initialized
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:11.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8235 (rev 00) IDE UDMA133 controller on pci0000:00:11.1
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:DMA
hda: ST340014A, ATA DISK drive
hdb: ST340016A, ATA DISK drive
Using anticipatory io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 1024KiB
hda: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(100)
/dev/ide/host0/bus0/target0/lun0: p1
hdb: max request size: 128KiB
hdb: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
/dev/ide/host0/bus0/target1/lun0: p2 < p5 p6 p7 >
hdc: TSSTcorpDVD-ROM TS-H352A, ATAPI CD/DVD-ROM drive
hdd: CD-RW IDE5232, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: hda1: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 1014339
ext3_orphan_cleanup: deleting unreferenced inode 850704
ext3_orphan_cleanup: deleting unreferenced inode 850703
ext3_orphan_cleanup: deleting unreferenced inode 850702
EXT3-fs: hda1: 4 orphan inodes deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Adding 2048184k swap on /dev/hdb7. Priority:-1 extents:1
EXT3 FS on hda1, internal journal
hdc: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
EXT3 FS on hdb6, internal journal
8139too Fast Ethernet driver 0.9.27
eth0: RealTek RTL8139 at <censuré>
eth0: Identified 8139 chip type 'RTL-8139C’
via-rhine.c:v1.10-LK1.1.20-2.6 May-23-2004 Written by Donald Becker
eth1: VIA Rhine II at <censuré>
eth1: MII PHY found at address 1, status 0x7849 advertising 05e1 Link 0000.
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ehci_hcd 0000:00:10.3: VIA Technologies, Inc. USB 2.0
ehci_hcd 0000:00:10.3: irq 21, pci mem f8832e00
ehci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:10.3: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 6 ports detected
NET4: DECnet for Linux: V.2.5.68s © 1995-2003 Linux DECnet Project Team
DECnet: Routing cache hash table of 1024 buckets, 8Kbytes
NET: Registered protocol family 12
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Linux agpgart interface v0.100 © Dave Jones
agpgart: Detected VIA KT400/KT400A/KT600 chipset
agpgart: Maximum main memory to use for agp memory: 816M
agpgart: AGP aperture is 128M @ 0xe0000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
shpchp: shpc_init : shpc_cap_offset == 0
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
ip_tables: © 2000-2002 Netfilter core team
NET: Registered protocol family 10
Disabled Privacy Extensions on device c02e7c20(lo)
IPv6 over IPv4 tunneling driver
ip_conntrack version 2.1 (7168 buckets, 57344 max) - 296 bytes per conntrack
eth1: no IPv6 routers present
eth0: no IPv6 routers present
fglrx: module license ‘Proprietary. © 2002 - ATI Technologies, Starnberg, GERMANY’ taints kernel.
[fglrx] Maximum main memory to use for locked dma buffers: 805 MBytes.
[fglrx] module loaded - fglrx 8.14.13 [Jun 8 2005] on minor 0
[fglrx] Internal AGP support requested, but kernel AGP support active.
[fglrx] Have to use kernel AGP support to avoid conflicts.
[fglrx] Kernel AGP support doesn’t provide agplock functionality.
[fglrx] AGP detected, AgpState = 0x1f000a1b (hardware caps of chipset)
agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
agpgart: Putting AGP V3 device at 0000:00:00.0 into 8x mode
agpgart: Putting AGP V3 device at 0000:01:00.0 into 8x mode
[fglrx] AGP enabled, AgpCommand = 0x1f000312 (selected caps)
[fglrx] free AGP = 118222848
[fglrx] max AGP = 118222848
[fglrx] free LFB = 122679296
[fglrx] max LFB = 122679296
[fglrx] free Inv = 0
[fglrx] max Inv = 0
[fglrx] total Inv = 0
[fglrx] total TIM = 0
[fglrx] total FB = 0
[fglrx] total AGP = 32768
[fglrx] max Inv = 0
[fglrx] max Inv = 0
[fglrx] max Inv = 0
[fglrx] max Inv = 0
[fglrx] max Inv = 0
[fglrx] max Inv = 0
cdrom: open failed.
ISO 9660 Extensions: Microsoft Joliet Level 3
ISO 9660 Extensions: RRIP_1991A
